November 21, 200322 yr Cylinder number one is the nearest the front of the car on the passenger side, right?
November 21, 200322 yr Author If you can real quick and the firing order is 1-3-2-4 spinnig clockwise??
November 21, 200322 yr Front passenger is #1 cylinder Firing order is 1 3 2 4 Distribution rotation is counterclockwise
November 21, 200322 yr is the dizzy properly timed to the crank and cam?? Remember that there are TWO TDC's of the #1 cylinder, needs to be @ TDC of the compression stroke. (With the timing marks at 0, both cam lobes for the #1 cylinder should be up)
November 21, 200322 yr front 2----1 4----3 back CalebZ told me a trick.. the #1 is always furthest forward on pretty much ANY engine.
November 21, 200322 yr Author Thats a good way to remember it. I gave up for the night. I will play with it again tomorrow. Thanks for all the imput guys!
