February 19, 200719 yr just wondering if a problem "code" can be displayed if the car will not start-up for some reason
February 19, 200719 yr Well yes and no, it depends why it isnt starting. Some codes wont show up, like the cam and crank sensor, since the car need to be running for them to show up as errors. Other codes it will store, but odds are those codes are not the ones that are keeping the car from running. Now if you have a start run stall situation, then yes it will hold codes. Also remeber the any kind of scan tool is just that, a tool, not a diffintive answer as to why the car has a problem. If your car is not starting, the easiets thing to do is to see if you have spark. The next would be to listen for the fuel pump, and then listen to see if you can hear the fuel injectors clicking. nipper
