ups came!
What struts are you running??? I dont know that much about suspension, just that remote resevoirs are really expensive.............. does tein also make shocks, probabbly but is that what you are running? and if so(questions forming and frothing in head) how do they run... after you get installed that is.
just trying to use with the gr2 struts. it appears i need to make a sleeve because they are a bigger diameter bore, and they came with a sleeve that was threaded, but for a diffrent set up.
Dude ADJUSTABLE CAMBER? :banana:
for goodness sake man paste a link to the site,for those of us sleeping during prior discussions.
Your info says you have a loyale. Is that what this is going on?
And also,do the GR2s come "cartarage only"? or are they alreadt inserted into the lower housing? on RX/LOYALE/WAGON EA82s?
THANX VERY MUCH:cool:
link to what? :confused: im not posting any writeup until this is all done.
they are one unit and about the same as oem. imo the rebound damping in them is a lil soft. i wish they had the same valving as the bilsteins in my jeep, well maybe that would be overkill. but i think the gr2 are emulsion and the jeep has monotube.
