the sucker king Posted November 25, 2003 Share Posted November 25, 2003 the last two mornings has been in the single digits or teens. this is my first winter with my ea81. the only way to get it started was to spray ether into the carb. the last 8 or so winters i was driving an ea71 with a manual choke i rigged up. i could always get it started, although the colder it was the harder it was. is rigging up this choke the only way to solve this problem? surely subaru did not sell a car that couldn't be started in cold weather. Quote Link to comment Share on other sites More sharing options...
torxxx Posted November 25, 2003 Share Posted November 25, 2003 get a block heater and oil pan heater.. plug your car in... it will start up every time Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted November 25, 2003 Share Posted November 25, 2003 You can install a manual choke apparently - someone just mentioned that. Ether really isn't good for your engine. Fix the problem as soon as you can. GD Quote Link to comment Share on other sites More sharing options...
Subaru IMP VR Posted November 25, 2003 Share Posted November 25, 2003 ALl that you need is the oil to be warm in the pan and it will work out fine get a 20gallon aqauarium heater and stick it to the bottom at night and you'll start everytime Quote Link to comment Share on other sites More sharing options...
Skip Posted November 25, 2003 Share Posted November 25, 2003 SK, You need to do a little homework, sorry to say. With the engine stone cold. Step on the gas pedal one time (half to three quaters of the way should suffice). This "sets the auto choke" Then take of the air cleaner top plate off (three wing nuts). The choke plate (top "flapper in the carb throat) must be totally closed. If it isn't, well out comes the ten (10) mm wrench. Pull the two bolts holding the aircleaner housing down. Gently lift it and spray a good lubricant ( not prefumed alcohol aka WD40) LPS #3 is good Triflo is best, all over the passenger side of the carb and it's linkage. Lower the assm. and try setting the choke again. You give no year so I will have to assume it has the rivoted autochoke assm. I.E. No adjustment, if it is internally knackered, go with a manual conversion or buy a repl. Hope this helps and yes Subys start in the cold very well when correctly set up. If the choke is setting it is possible your carb is "bleeding down"do your homework and if it's bleeding down the start proceedure is a bit different Quote Link to comment Share on other sites More sharing options...
torxxx Posted November 25, 2003 Share Posted November 25, 2003 what works the best for an oil pan heater that I've found is a battery blanket. Soob oil pans are about the same size as the battery thats used in the car... When I put mine on this year, all you have to do is drop the oil pan skid plate and wrap the blanket around the oil pan, secure with one piece of bailing wire, then put the skid plate back on.. the plate holds the batt. blanket in tight against the oil pan... Mine car starts fine even at -40 F Quote Link to comment Share on other sites More sharing options...
incognito Posted November 25, 2003 Share Posted November 25, 2003 Yeh even mine starts in -20.... i dunno why single digits would be a problem. Get a damn good battery (i always run 1000+ CCA) and keep the motor turnin... It'll fire... Quote Link to comment Share on other sites More sharing options...
