halyva Posted May 2, 2007 Share Posted May 2, 2007 Forester 2001 5 speed MT does one misfiring sometimes when an engine goes from high rpm to idle. For instance when I accelerate and then put on neutral an engine produces a single misfiring. It does it very seldom. Any ideas how to resolve this issue? Quote Link to comment Share on other sites More sharing options...
nipper Posted May 2, 2007 Share Posted May 2, 2007 how many miles ? nipper Quote Link to comment Share on other sites More sharing options...
halyva Posted May 2, 2007 Author Share Posted May 2, 2007 how many miles ? nipper Thanks nipper for VC advise. I have 93,000 miles Quote Link to comment Share on other sites More sharing options...
nipper Posted May 2, 2007 Share Posted May 2, 2007 Almost sounds like a fuel injector issue. When was the last time this thing had a tuneup? ALso have the codes pulled. nipper Quote Link to comment Share on other sites More sharing options...
halyva Posted May 2, 2007 Author Share Posted May 2, 2007 I don't get any error codes... but have not done tuneup for a while... Likely it's time. I will start with injector cleaner and sparkplugs.... Thank you. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 2, 2007 Share Posted May 2, 2007 I don't get any error codes... but have not done tuneup for a while... Likely it's time. I will start with injector cleaner and sparkplugs.... Thank you. Fuel filter too Quote Link to comment Share on other sites More sharing options...
cookie Posted May 2, 2007 Share Posted May 2, 2007 Plug wires too. Quote Link to comment Share on other sites More sharing options...
nipper Posted May 2, 2007 Share Posted May 2, 2007 Plug wires too. OE plug wires Quote Link to comment Share on other sites More sharing options...
Olnick Posted May 3, 2007 Share Posted May 3, 2007 Yeah, and wax the car too. (Shiny cars always run better!) Quote Link to comment Share on other sites More sharing options...
OB99W Posted May 3, 2007 Share Posted May 3, 2007 Yeah, and wax the car too. (Shiny cars always run better!) Of course, but cleaning other parts may make more of a difference. For example, if the EGR valve isn't fully closing (or closing fast enough) as the engine falls back to idle, the mixture will be excessively leaned; that can cause misfire. If there's carbon buildup at the EGR, cleaning it may resolve the problem. Quote Link to comment Share on other sites More sharing options...
halyva Posted May 3, 2007 Author Share Posted May 3, 2007 Thank you for all your ideas. I will try this weekend. This is what weekends are for........ Quote Link to comment Share on other sites More sharing options...
