May 3, 200718 yr Before swapping my cv axle wanted to double check. Haynes doesn't mention axle nuts as having reverse thread so I assume both sides are regular thread ie turn counter-clockwise to loosen??
May 4, 200718 yr Both sides are standard right handed threads. 145 ft-lbs to tighten, but you can use more if you like.
May 4, 200718 yr No. Generally I agree, but that's not excactly true. With subaru roller bearings, you don't have to worry about an excact adjustment. Force from the axlenut should just hold the axle through the hub, not load the bearing. BUT, I think there is a point were they would be too tight. It would be really hard to get it too tight with conventional tools, but if you go more than say 350 ft.lbs(just a guess) I think it could hurt them. But it's not like the old tapper bearing setup that had to be adjusted *just so*. Those kind it's easy to crush the rollers.
May 4, 200718 yr Generally I agree, but that's not excactly true. With subaru roller bearings, you don't have to worry about an excact adjustment. Force from the axlenut should just hold the axle through the hub, not load the bearing. BUT, I think there is a point were they would be too tight. It would be really hard to get it too tight with conventional tools, but if you go more than say 350 ft.lbs(just a guess) I think it could hurt them. But it's not like the old tapper bearing setup that had to be adjusted *just so*. Those kind it's easy to crush the rollers. You're right about 350 ft-lbs. Won't hurt the bearings but might break something else. I've always tightened them past 175 to be sure they were on there "good 'n tight." The point is the only critical thing here is if they are too loose.
May 14, 200718 yr Ahh, the old german torque spec's. Gootentite! I'm of German heritage... I'd have to agree with that one... My Dad (right off the boat) was/is a retired machinist would have to agree too...
