oil level
ok so this may be a really dumb or obvious question but....
I have an 82 Gl wagon with a EA81 and if i check the oil level while it the engine is cool and has not been driven in awhile it shows full
but if i check it at the gas station it shows it needs a quart
Which one do i go off of???
I am running synthetic oil
Maybe it is a Dumb way to Answer, but: The car is Placed in a Flat Ground while you check the Oil Level? ...
I Ask you that, ´cos I knew a case of a boy who checked his Car´s oil level in his Garage, with a 10º on the Floor... :-\
Also: Let your car´s engine "rest" for a While in the Gas Station before check it, it not only lets it cool down a Li´l Bit; it also lets the amount of Oil that will remain on the Valve´s train, to find its way down to the carter again, so You´ll check it more accurate. :)
Good Luck! :burnout:
there is only one way to find out. Let it sit for a few minutes, THEN check it. Get out, pay for your gas, pump, finish pumping, then check your oil just before re starting.
It is best to check the level when the oil is warm. After turning off the engine, wait a few minutes for the oil to drain back into the oil pan before checking the level.
It is a boxer engine, after all, and not an inline.. it takes some time for it all to drip back down.
I've noticed it takes longer than just a few minutes for the oil to completely drop back into the pan... more like ten
Then again, if you're topping off the good old 16 gallon tank from empty (our gas pumps here get slow some times) its more than enough waiting time, to check oil right afterwards
Me personally, I just check it in the morning after the car's been sitting, just to be 100% sure
