mikeshoup Posted June 28, 2007 Share Posted June 28, 2007 How the heck do you guys remove the cam seals from the support? I can't get the damn thing out. Quote Link to comment Share on other sites More sharing options...
Gloyale Posted June 28, 2007 Share Posted June 28, 2007 seal puller if not, remove the cap and use a punch Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 28, 2007 Share Posted June 28, 2007 Easy - drill a small hole and thread a wood screw into it. One on each side if you need - then grab with pliers and pull. GD Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 28, 2007 Share Posted June 28, 2007 EA81 or 2? in the car or out of the car? it's easiest if you can remove the cam cap with the seal in it, but i don't know if you can do that on EA81's? drill a pilot hole or use a self tapping sheet metal screw if you can find one small enough. then use a hammer under the head of it to get it started coming out. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted June 28, 2007 Share Posted June 28, 2007 EA81 or 2? in the car or out of the car? it's easiest if you can remove the cam cap with the seal in it, but i don't know if you can do that on EA81's? Owing to the fact that EA81's are not OHC, they don't have cam seals. GD Quote Link to comment Share on other sites More sharing options...
