July 3, 200718 yr I know there are several threads about torgue bind but i could find what i was looking for. Is there any specific type of auto tranny fluid that helps better then others.
July 3, 200718 yr Clean fluid. Some add Lucas LSD additive which helps depending upon the cause of the TB. nipper
July 4, 200718 yr Yes, the LSD limited slip differential additive can be something to try, and Subaru recommended it for certain vehicles at some point if there was binding. Beyond that, a good Dexron fluid should do the job. Some synthetic multi-purpose ATF's that are also suggested for Dexron apps may be more heavily friction modified.
July 8, 200718 yr I purchased the additive from a dodge dealship. But I never used it, I had my tires rotated and balanced to fix the issue (Thanks Nipper)
July 8, 200718 yr The instructions on the bottle of the limited slip additive are going to be for its normal use in gear oil. I'm trying to find the TSB or wherever Subaru said to use the GM limited slip additive for binding. I haven't searched too much yet but someone on nasioc said "The info about limited-slip additive can be found in Nov. 1996 TIPS newsletter." I haven't tried royal purple. Have tried amsoil synthetic atf and mobil1 synthetic atf and those worked fine. The generic autozone atf seemed to work fine too.
