Nate007 Posted August 13, 2007 Share Posted August 13, 2007 just got my system recharged in my '92 SVX and now it doesn't work. It's really hard to explain what it does, I turn it on auto and it does'nt even blow any air. I'm thinking it's the temp sensor for the climate control. the compressor runs fine and the clutch works, all fuses and relays have been checked. Quote Link to comment Share on other sites More sharing options...
elborak Posted August 13, 2007 Share Posted August 13, 2007 Is that R-12 or R-134a? Quote Link to comment Share on other sites More sharing options...
uniberp Posted August 13, 2007 Share Posted August 13, 2007 just got my system recharged in my '92 SVX and now it doesn't work. It's really hard to explain what it does, I turn it on auto and it does'nt even blow any air. I'm thinking it's the temp sensor for the climate control. the compressor runs fine and the clutch works, all fuses and relays have been checked. Did the shop that recharged it notice any of these things? Quote Link to comment Share on other sites More sharing options...
Nate007 Posted August 13, 2007 Author Share Posted August 13, 2007 I had it recharged with R-12, and it worked like a dream for a few days. now it's on the fritz Quote Link to comment Share on other sites More sharing options...
BoostedLegacy Posted August 13, 2007 Share Posted August 13, 2007 I had it recharged with R-12, and it worked like a dream for a few days. now it's on the fritz If you haven't already, check the fuses over again. I imagine you already have but just in case.... Quote Link to comment Share on other sites More sharing options...
Nate007 Posted August 14, 2007 Author Share Posted August 14, 2007 I checked, rechecked and double checked the fuses/relays. theyre all fine. i'm thinking it's the temp sensor for the climate control Quote Link to comment Share on other sites More sharing options...
nipper Posted August 14, 2007 Share Posted August 14, 2007 Go over to the SVX board, they can be more help over there. nipper Quote Link to comment Share on other sites More sharing options...
Blue Whale Posted August 14, 2007 Share Posted August 14, 2007 You said it doesn't even blow any air? Does the automatic control in the SVX turn off the fan when the compressor isn't running? If not, your problem may be with the fan circuit: without the fan running, the compressor clutch won't engage (if it did, your evaporator would be encased in a block of ice after a short while). Quote Link to comment Share on other sites More sharing options...
