swapping out carter weber intake w/ hitachi set-up
im doing this cuz i think i have a lot better of a chance with passin smog...is this an easy swap???......for a noob??? will this help me pass smog a little better?
-Dalton
Short answer - not really for a noob, no. Hitachi's are the spawn of satan, and the C/W is actually easier to work on.
Get a Weber DGV. It will be cheaper once it's all said and done.
GD i need something that can pass smog and one of the reasons i failed is becuase i was missing a hose.(visual inspection)...i dont think they will pass me if all the hoses are plugged off...plus i need a weber and i dont know where i can find one. if you know anybody who has one pm me.
-Dalton
The Weber's are availible new in a kit from Redline - K731 or K730 depending on EA81/82. They run about $375
Find another place to do the inspection that doesn't do a visual - not all do, and plenty from WA have smogged Weber'd EA81's - talk to Edrach I know he's done it.
Or retrofit the SPFI - it's not really as hard as it sounds, less expensive than a weber, and you'll easily pass a visual.
well thats what i'd really like to do is SPFI. but i'd need some help on that one ,and the only person that could help me with that is subieman and he's really busy.
i know where i could find parts tho:grin:
how much would you charge for a harness prep?
...im not made of money but i got a little, plus stuff to trade.
-Dalton
Sadly I really don't have time for making harnesses right now - I was going to make some but the intrest just isn't there. Not enough people that are skilled enough or that want it badly enough to swap from the Weber to the SPFI - even I am going to switch to MS in the future. I have vehicles needing work stacked up for the next 6 months at least - half of which aren't even mine :rolleyes:, and I've been working tons of overtime at work - four 16's in a row last week :eek:
i just started reading your spfi swap and nearly SH###T myself.
i need a weber, but i dont got 375$$$
-Dalton
You gotta start out somewhere man. Don't be scared of the spfi swap. Its one of the simplest motor upgrades you could do.
I will do the wiring and disty gear swap if you want.
illl think about it....it would be cool if i could try it on some other car, maybe to see if i could get it to run right...
thanks for the encouragement
-Dalton
  • 2 weeks later...
I carumba. I know you gotta start somwhere, but methinks this isn't the job converting and all. Not for Noober.
well it turns out that its the exaust thats messing with me.....fun huh?
-Dalton
