Documented: The 1970 FF-1 Project car...
Honestly Id split it, the bearings have prolly been in there since it was new, and it would prolly be a good idea to replace all the bearings and check for excessive wear and such. Plus it would give you the chance to get the cam reground and make everything spotless for a little while anyways
-Bill
  • Replies 1.6k
  • Views 329.5k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • OMG! FINALLY! She will live again!  THE HOLE.... IS GONE! (more photos to come soon - i just opened the box, crappy phone pix!)       Now the fun begins.
  • SEAT PHOTOS!   Again, seats are from a 1982 Mazda GLC. They were from the original owner, who'd removed them from his car when new to install Sparco seats. Sat in his basement for 30 years waiting
  • Horns work!  (BEEP BEEP you've been warned!)   click here for video       Engine will be back inside of the car TODAY
Posted Images
Thats honestly what I want to do, but I cant find those sleeve gasket thingies anywhere... I can find bearings (although none stock size so far, either + size or - size) and piston rings, but thats it.
The sleeve gasket don't come in one size fits all, they come in different thickness to suit your engine, you can get away with a copper gasket once you know what your thickness you need, from memory you need to have the sleeve protrude the block by about 3 thou so it give possitive sealing on the gasket and a good seal around the head gasket. common problem why head gaskets kept on failing once the headgasket was ever replaced. Also applies to the 1400 ea63
Thierry
I wonder if you could get some of those sleeve gaskets things made up in copper by one of the places that make race copper head gaskets?
bullsh****t!!!!! it would be way cooler to build up a 1.1 cuz nobody has one! everyone with a first gen basically has a Ea71....(besides pre-76')
There's no replacement for Displacement.
I think all the time and effort spent on the 1100 would be better served on a 1600.
Thats what I need to know... If anyone has or can make the required parts.
Well I went ahead and split the block today...
Good thing I did, I found the center main bearings are damaged and the rest do need replacing. I didnt completely split the block though, left the pistions in, just split it enough to get out the camshaft and look inside.
The camshaft needs a little help too, its got some damage too...
Wow, someone in Japan actually has pictures of an aftermarket muffler for the FF-1...
i wonder if there is a chance of still finding that muffler? it looks nice and im sure it sounds great as well.
I think everything on that website is custom, but it is good to use as something to work with design wise...
Anyway, I removed the transmission today, took a couple photos so you can get an idea of exactly how TINY this drivetrain is!
I also removed the steering column and ventilation system, but I didnt photograph that today.
Heres a couple things I picked up on E-bay for really cheap that I wanted to see if were compatible with the EA61...
Now the valves obviously are larger, but i'm concerned more about the length. The length will probably cause them to be incompatible, but i'm not sure if that can be fixed. I now some custom head work can fit the valves into the sockets, but thats different than modifying the valves themselves.
The camshaft on the other hand looks to be rather compatible. Might require some work to use, but nothing major. The interesting thing is the lobes are taller, which means more lift, but the duration looks simular but sharper. I have all the actual camshaft numbers if anyone is interested in figuring out if the 1300/1400 camshaft is actually an upgrade for the 1100... (I bought it mostly cause I do believe this stock camshaft is shot, and a NOS camshaft that can be modded by someone like Deltacams is something useful to have)
I just measured the camshaft. The EA61 camshaft has 31mm lift, while the EA62/63 camshaft is ~33mm. Sound like a good improvement?
Measure those valves, let me know how much longer the 1300 valves are. You MIGHT be able to cut them down (You'd have to have a machine shop do it, since you'd need a valve grinder) and have them work, but I'm not sure... I have a valve grinder...
Why not try and use some taller valve springs? See how the springs from the 1300, 1400 and 1600, hell even the 1800 compare to the 1100... might be taller then which you can use those valves without having to mod them at all.
I havent seen any valve springs for sale, i've been looking. If you know somewhere or someone that has some, let me know.
Also, need to figure out which ones have which tensions... Dont really want ones with lower tension rates, higher if possible.
Even cutting them down, what about the distance beetween that clip slit and the top of the valve stem, doesnt that need to be the same?
So this is coming from my '78 FSM, reprint in '82. These are the factory specs for the EA71 in '78...
Outer spring Inner Spring
Free Length 48.20mm (1.898 in) 48.65mm (1.915 in)
Solid height (fully compressed) 29.5mm (1.161 in) 25.6mm (1.008 in)
Tension/spring height intake 18.13-20.87 kg 8.93-10.27 kg
(39.97-46.01 lb) (19.69-22.64 lb)
/39mm (1.54 in) /37mm (1.46 in)
exhaust 41.3-47.5 kg 19.53-22.47 kg
(91.05-104.71 lb) (43.06-49.54 lb)
/31mm (1.22 in) /28mm (1.10 in)
Squareness 2.1mm (.083 in)
The 1100/1300G FSM doesnt show intake and exhaust valve specs, just one set of specs...
Outer spring:
42.2mm free length, 4mm wire diameter, 26mm maximum compressed length, maximum tension 43.7~50.3kg@28mm.
Inner spring:
45.5mm free length, 2.6mm wire diameter, 24.3mm maximum compressed length, maximum tension 19.1~22.1kg@26mm.
The EA71 tension is lower on the outter spring, SLIGHTLY higher on the inner spring, and half a cm taller...
It looks like however the BEST valve springs are the "Sport" (IE dual carb, 95hp EA62/63) valve springs... But theres no way to get those, and if I could, i'd want the WHOLE engine :-p
I just foun d the specs for the '74 1400 as well. When I get a few minutes, I'll start putting together something that will have all the spring specs out of the FSMs I have for future reference.
That would work if you had shorter pushrods made, since I don't think there is enough movement in the lash adjuster to adjust all that difference out. As for the slit to the tip of the valve distance, as long as there is enough stem sticking up that the rocker tip doesn't contact the spring retainer, it's okay, but good point, you don't want it too short, that's why I wanted measurements of the valve length...
What about in combination with the cam with the taller lift?
Anyway, another question...
Transmission thoughts:
Front LSD possible? How about converting to a lower final gear (IE changing this from the stock 4.125 to 3.8 or 3.7? Assuming its simular to other EA 4-speeds...
Front LSD won't work since I think the earliest that's the same as the 04 is 85, there is a thread on this.
Changing the final drive is a no-go, the ring gear is removable from the differential carrier, however the pinion is part of the countershaft of teh transmission, and has gears cast into it, so you can't change it unfortunately.
As for the valves, one of the critical valve train measurements is teh installed height of the valve spring retainer, and the stem height of the valve. Stem height is the distance from the spring seat in the head to the tip of the valve stem. Installed height is the distance from the spring seat to the top of the spring retainer, with the valve installed in the head. You get those two measurements correct and you should be good to go, but it's been too long since I've rebuilt a head to be 100% sure. (I'm about 88% sure)
You should be able to send your cam to Delta and have them grind it, and see if they will resurface your lifters as well, since ideally with a new cam, you'll want a smooth surface for the cam to ride on, not one that's been worn by the old cam. Qman had a pretty lumpy cam in one of his Brats, I saw it at an autocross once, it sounded pretty mean!
Once you get that all figured out, it's just a matter of getting the valve lash properly adjusted, and breaking the cam in (Might not be needed with a reground cam, but I am not sure, I know with a new cam you have to run it at 2500 rpm or more for 20 minutes, at least that's what I've had to do with the last 2 cams I've put in.)
Great info, thanks!
Keep in mind, the whole engine wont be in and running for quite some time... (years possibly at this rate) But it helps to have as much info here as possible so I can reference it when needed :)
Great info, thanks!
If you need any more info on the older engines, let me know since I got FSMs to cover them all basically (even your FF1):banana:
