eseiler Posted September 28, 2007 Share Posted September 28, 2007 Hello, Cylinder #2 on my EJ22 engine is misfiring (according to OBD codes)...facing the engine from the front...which cylinder is #2? Note: the ECM is for an EJ25 engine (swapped a EJ25 for an EJ22 in an automatic 96 OBW) Thanks! Damien Quote Link to comment Share on other sites More sharing options...
nipper Posted September 28, 2007 Share Posted September 28, 2007 Hello,Cylinder #2 on my EJ22 engine is misfiring (according to OBD codes)...facing the engine from the front...which cylinder is #2? Note: the ECM is for an EJ25 engine (swapped a EJ25 for an EJ22 in an automatic 96 OBW) Thanks! Damien Drivers side - pass side Front 1-----------------2 3-----------------4 Quote Link to comment Share on other sites More sharing options...
eseiler Posted September 28, 2007 Author Share Posted September 28, 2007 Drivers side - pass side Front 1-----------------2 3-----------------4 Hey Nipper...you should be getting paid for all the work you do on this forum! --Damien Quote Link to comment Share on other sites More sharing options...
nipper Posted September 28, 2007 Share Posted September 28, 2007 Hey Nipper...you should be getting paid for all the work you do on this forum! --Damien Not to hijack the thread, but it keeps me happy and my skills sharp. Whatever i don't know i will find out about. It gets boring being home on disability. Right now I am trying to figure out what my next career path will be. I enjoy it. nipper Quote Link to comment Share on other sites More sharing options...
Manarius Posted September 29, 2007 Share Posted September 29, 2007 Nipper, from the front, it's back 2 4 1 3 Front I'm pretty sure it's that way because 4 is near the driver and it gets lean all the time.... Quote Link to comment Share on other sites More sharing options...
OB99W Posted September 29, 2007 Share Posted September 29, 2007 Wow, this is getting confusing. Standing at the front of the car, looking down at the engine, the odd numbered cylinders are on the left (passenger's) side, the even on the right (driver's) side, lower-numbered nearest you: 3 4 1 2 Quote Link to comment Share on other sites More sharing options...
Manarius Posted September 29, 2007 Share Posted September 29, 2007 Wow, this is getting confusing. Standing at the front of the car, looking down at the engine, the odd numbered cylinders are on the left (passenger's) side, the even on the right (driver's) side, lower-numbered nearest you: 3 4 1 2 Yeah, OB, I believe you've got it right. I just wish I had my coilpack here to look to make sure, but the way you have it looks right to me. Quote Link to comment Share on other sites More sharing options...
nipper Posted September 29, 2007 Share Posted September 29, 2007 Nipper, from the front, it's back 2 4 1 3 Front I'm pretty sure it's that way because 4 is near the driver and it gets lean all the time.... I got it backwards, #1 and #3 are on the pass side (sorry about that) 1-2 3-4 Per haynes thats the location of the cylinders. Firing order is 1-3-2-4 http://autorepair.about.com/library/firing_orders/bl-fo-1140.htm They are all basically the same since the first boxer. nipper Quote Link to comment Share on other sites More sharing options...
PAezb Posted September 29, 2007 Share Posted September 29, 2007 Nipper, from the front, it's back 2 4 1 3 Front I'm pretty sure it's that way because 4 is near the driver and it gets lean all the time.... That's what I thought, but I found this Endwrench .pdf, which if you refer to page 14, the description on installation of the camshaft sprockets and cam belt idler pulleys, working from the front, agrees with Nipper's original designation... http://68.178.49.203/jon/EJ22-Overhaul.pdf :confused: :confused: :confused: Quote Link to comment Share on other sites More sharing options...
Manarius Posted September 29, 2007 Share Posted September 29, 2007 I am almost 100% positive that number 4 is the closest to the driver. Quote Link to comment Share on other sites More sharing options...
eseiler Posted September 29, 2007 Author Share Posted September 29, 2007 ok...#2 is on the driver's side...is it nearest the driver or nearer the front of the car? D Quote Link to comment Share on other sites More sharing options...
PAezb Posted September 29, 2007 Share Posted September 29, 2007 ok...#2 is on the driver's side...is it nearest the driver or nearer the front of the car? D Nearest the front of the car, driver's side headlight, according to nipper's link... Quote Link to comment Share on other sites More sharing options...
Manarius Posted September 29, 2007 Share Posted September 29, 2007 Nearest the front of the car, driver's side headlight, according to nipper's link...Straight from the FSM: Quote Link to comment Share on other sites More sharing options...
PAezb Posted September 29, 2007 Share Posted September 29, 2007 Bingo...! Quote Link to comment Share on other sites More sharing options...
OB99W Posted September 29, 2007 Share Posted September 29, 2007 Straight from the FSM: I rest my case. Quote Link to comment Share on other sites More sharing options...
zstalker Posted September 29, 2007 Share Posted September 29, 2007 easiest way to remember, the cylinder closest to the front of the motor is number always #1, on every motor, every make. And no, boxer and V motors aren't straight across from eachother, just pretty close...but there's always one more forward than the other. On Subaru motors, think about where the water pump fits, its front is level with the front of the other side of the motor, so it must be on the more-rearward side....make sense? Sorry if I'm confusing anyone. The number one cylinder is right against the timing belt, on the (car's) right side, the number 4 is on the back, tucked against the starter. Numbering is right, left, right, left (unless you're Ford... sheesh). ~Erik~ **************brake **************master *************cylinder ***(turbo)*******4 ******3 ***************2 ******1 ****head******head ****light*******light Quote Link to comment Share on other sites More sharing options...
