December 8, 200718 yr Where could I pick up a set of these strut tops? Boneyard, or a dealership (prettyr sure they are still available) If not try a Hastings/Pepboys/Murrays etc...
January 4, 200818 yr Boneyard, or a dealership (prettyr sure they are still available) If not try a Hastings/Pepboys/Murrays etc... Hondaslayer, my inspiration. got hold of a set of 2000 forester strut/springs. Kept the forester tophats because they are much bigger and quite frankly are made for the taller assembly. but it required a slight drilling and slotting of the rear strut towers. finding your swap set is like searching for the holy grail. mine have 94k on them but rides like a new car. if you can buy 2 set-it will be cheaper and last longer than 1 new set. [/img] I don't think I'll be changing struts for the seasons-this is the OBSter now. fyi, check with auto brokers-they have parts cars galore and sometimes you get lucky. Jon
January 23, 200818 yr I got the FXT struts front and back. I had to take a dremel and slot some of the mounting holes in the rear and then I used big fender washers to keep things intact. Have about 3k on them' date=' no problems. Here is before and after [img']http://i81.photobucket.com/albums/j208/boswan/StockOBS.jpg[/img] Your wagon looks awesome! I just picked up a 96 like yours and it's sitting low. With 180k miles, the shocks are definitely shot. I'd love to raise it up like yours. Can you tell me exactly what I need to buy to do it? What year and model forester should I get the struts from? Are the parts "bolt on" or do I need to do any modifications to make them fit? What should I expect to pay for the 4 strut assemblies from a junk yard? thanks for your advice! -Don My car.
