tcspeer Posted October 24, 2007 Share Posted October 24, 2007 1997 Subaru Legacy Wagon, are the threads on the tie rods all left hand? And is it better to remove rods at inner and then put in vice to remove the outers. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 25, 2007 Share Posted October 25, 2007 yes they are all normal left hand threaded. no need to remove the inners to replace the outers. the outers have a flat spot on them for a wrench/or other tool. hold it in place while you turn the outers off. Quote Link to comment Share on other sites More sharing options...
tcspeer Posted October 25, 2007 Author Share Posted October 25, 2007 Gary, I need to replace the inner ones also, I have never changed inner tie rods they look strange are those little washer things just locks to keep them from unthreading? Must I have the claw wrench to undo these or can they be taken off with vice grips or small pipe wrench? yes they are all normal left hand threaded. no need to remove the inners to replace the outers. the outers have a flat spot on them for a wrench/or other tool. hold it in place while you turn the outers off. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted October 25, 2007 Share Posted October 25, 2007 i've never replaced a subaru inner tie rod end. do you have an FSM to look at, i would suspect it's fairly straight forward, the trucks i've seen are very simple. unthread, screw in the new one. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted October 25, 2007 Share Posted October 25, 2007 I looked at FSM for '96 Legacy; diagram is below. For inner tie rod it says 'see steering gear', then it shows a couple basic things with the washer and some special tools, with the rack out of the vehicle. Quote Link to comment Share on other sites More sharing options...
Hocrest Posted October 25, 2007 Share Posted October 25, 2007 Gary, I need to replace the inner ones also, I have never changed inner tie rods they look strange are those little washer things just locks to keep them from unthreading? Must I have the claw wrench to undo these or can they be taken off with vice grips or small pipe wrench? Yeah, that "washer" has some tabs bent over to keep it from un threading. Use a screwdriver and hammer to bend them out of the way. Then either a big wrench, adjustable wrench or pipewrench to turn it loose. Quote Link to comment Share on other sites More sharing options...
tcspeer Posted October 26, 2007 Author Share Posted October 26, 2007 Thanks Hocrest, I have never done these and was not sure about the correct way. Yeah, that "washer" has some tabs bent over to keep it from un threading. Use a screwdriver and hammer to bend them out of the way. Then either a big wrench, adjustable wrench or pipewrench to turn it loose. Quote Link to comment Share on other sites More sharing options...
tcspeer Posted November 4, 2007 Author Share Posted November 4, 2007 I managed to get the inner tie rods changed without the proper tools, However I got the inner tie rod tool I ordered yesterday. What a tool, it's a large pipe looking thing that slides over the inner rod, at the end near the engine you place one of the crow foot that fits the tie rod you are working on. On the other end is a socket hole to insert your breaker bar. This is a great tool I would not suggest changing these rods without it, I only paid 39.00 dollars for it from Harbor Freight they are 99.00 dollars from snap on. But I would think you should be able to rent these from some of the auto part stores. The picture of this tool is misleading it is much bigger and better then it looks on the tool site. Quote Link to comment Share on other sites More sharing options...
porcupine73 Posted November 5, 2007 Share Posted November 5, 2007 Good info! So how do you know you have an inner tie rod problem? Is there noticeable looseness or anything? Quote Link to comment Share on other sites More sharing options...
tcspeer Posted November 5, 2007 Author Share Posted November 5, 2007 Yes, their was play in the front wheels at nine and three very noticeable. I also had the left front bearing out and I used the info. someone else posted on the board a while back about how to find it, I would like to credit that person but I dont remember who gave the info. Their info. was to raise the tires off of the ground and turn the tire while holding your hand on the spring you can easly feel the vibration in the spring it is a very good tip. Back to the tie rods if you order these from Subaru make sure to order the new lock washers they are not like reg. lock washers so you need these, my old ones were not in good shape. I went to Midas for a alinement after changing mine and the manager there who I have come to know well after many years told me that the tie rods made by Moog are better then the O.E.M. and he said they will come with the new locks. Good info! So how do you know you have an inner tie rod problem? Is there noticeable looseness or anything? Quote Link to comment Share on other sites More sharing options...
