EVOthis Posted November 16, 2007 Share Posted November 16, 2007 I have no idea about even starting to install a turbo....the #1 question i have is that if you make your own exhaust manifold......can you pretty much use any turbo you find out there.....i found 1 in a junk yard in a relativly new car and the bearings check out and it looks really good (borg warner) but can you retrofit it.... Quote Link to comment Share on other sites More sharing options...
idosubaru Posted November 16, 2007 Share Posted November 16, 2007 NASIOC is probably a better source for turbo info if you can get them to talk without making absurd comments. or they may have links, write ups and FAQ's about it. i'd probably look to see if EJ22 turbo manifolds and exhaust would bolt right up, that would be the easiest option. i know people on here have done this before (turbo a non-turbo EJ22) but whether they see this or respond is another question, they aren't the most active members. do some searching for Myxalplyx, he used to have a turbo installed on his EJ22 Impreza Outback Sport. He installed the turbo, ran some great times, removed it and the car has been dead solid reliable since he's owned. Quote Link to comment Share on other sites More sharing options...
subaru360 Posted November 16, 2007 Share Posted November 16, 2007 It's not as simple as just bolting on a turbo. The turbo has to be sized to the engine. You need the right engine management for a turbo and you'll need to upgrade the fuel system. Do your research before getting in to a project like this. If you're new to working on cars and still want to go ahead with it, probably your best bet is to swap a complete turbo engine with harness and ecm to make it as simple as possible for yourself. Quote Link to comment Share on other sites More sharing options...
EVOthis Posted November 16, 2007 Author Share Posted November 16, 2007 It's not as simple as just bolting on a turbo. The turbo has to be sized to the engine. You need the right engine management for a turbo and you'll need to upgrade the fuel system. Do your research before getting in to a project like this. If you're new to working on cars and still want to go ahead with it, probably your best bet is to swap a complete turbo engine with harness and ecm to make it as simple as possible for yourself. oh im not new to working on cars by any stretch.....actually im a mechanic.....but im just new to working with turbos...... Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted November 17, 2007 Share Posted November 17, 2007 If you're new to turbos, go get the book "Maximum Boost" by Corky Bell. Its a great book to learn everything but this books is not for the faint of heart as they go over every detail of turbos. Also known as the Bible of Turbos. Quote Link to comment Share on other sites More sharing options...
EVOthis Posted November 18, 2007 Author Share Posted November 18, 2007 thanks for the tip....i actually just went out to get the book......looks like i have alot of reading to do.....appreciate the help Quote Link to comment Share on other sites More sharing options...
86BRATMAN Posted November 18, 2007 Share Posted November 18, 2007 You can find a lot of guys selling thier stock turbo/up/down pipes if you look around, and switch off to the engine crossmember from a 91-94 turbo legacy. Then all you've got to worry about is tuning, and that sort of thing. Well that and single port heads. Quote Link to comment Share on other sites More sharing options...
Storm Posted November 20, 2007 Share Posted November 20, 2007 What did the turbo come off of? If the displacement was similar, it's more than likely suitably sized for your motor. Start welding up an up pipe and flange assembly. If you got the book by corky bell, you're on your way to understanding how they work, what they need to be reliable and what things you want to keep an eye on. Most of the cautions that get thrown around on nasioc are meant for people who expect the solution to come from the box. The general feeling I get from this community, is that y'all can basically make anything work well enough for your needs. You will learn alot about the differences between tuning forced induction versus naturally aspirated motors. Go for it and build up the boost levels slowly, while keeping an eye on temps, plugs, A/F ratios, etc..... Jay Storm Quote Link to comment Share on other sites More sharing options...
Andyjo Posted November 26, 2007 Share Posted November 26, 2007 if the pipes are still connected to the turbo, you might want to thing about grabbing those too, and just re-work (cut & paste ) the port sections, with some slight modification. Quote Link to comment Share on other sites More sharing options...
