1600 or 1800 engine, how can you tell ?!
Simple question. I'm looking for a manual for my 82 4wd GL Wagon, and i am unsure about the size of the engine. :burnout:
Any advice appreciated.
Well, I'm sure there are other ways...But on the heads you should find a casting number, EA71 being a 1600 and EA81 being the 1800. There are probably easier ways though. :)
82 GL 4WD would be an EA81. They didn't put EA71's in the 4WD GL's after 81.
I knew it was an EA81 by the casting, but from this page
it seems there are 2 versions of the EA81. No designation of which vehicle has what though.
I believe the first version of the EA81 was the fat case EA71, but 'm not totally sure about that, but your car being a GL, I'm pretty sure it has the standard EA81 motor.
Big valve/small valve, yeah.
83+ has larger intake valves. They rated them 1 HP higher.
83/84 Auto's and all 85+ have hydro lifters.
1800 it is then,
thanks for the replys.
1800 it is then,
That page is poorly layed out, and possibly incorrect on a couple points.
I think you are under the impression that there is a size difference in the EA81's. That is incorrect.
EA81 = 1800cc
EA71 = 1600cc
ALWAYS.
I was indeed under that impression. Thank you for clearing that up.
Oh well if anyone reads this with a DL there is a 1982 1600 FSM on ebay for 10 bucks BIN.
1600 (ea71) have a light blue valve cover, While 1800(ea81) has A more green or sea green color to it. Thats the main way I always tell.
Jeff
