local JY run
:banana: :banana: :banana:
Went to the local JY Carney's Ames, IA $80 for right front headlight assembly, and corner lamp, heat-air controller,
fuses, trim panel for around fuse box, 4WD red shift knob,
owner's manual supplement and other info, dowel rod
Trecel tilt-o-meter, shft knob, and 4wd knob
Left 5 minutes before closing time! They are really nice.!
?How do i set up the Trecel tilt-o-meter?
is it a pull it yourself type of yard? been meaning to get up there sometime...
the inclinometer from the tercel will work without anything else. the wires are only for the lighting.....
Carney's 515-232-5874 or 1-800-262-3808
Ames off of Hwy 69 by B-BOPS
You may pull-it-yourself if you ask.
ask them where the subarus are on the aerial photograph, makes hunting easier, also ask for a current list of the cars in their "public" yard
They are super-nice to work with.
