February 5, 200818 yr Author I wonder why subaru doesn't offer the 2.2L engine as a cheaper option to the 2.5L on all new cars? It would save them millions on warranty repairs alone. the problem motor only last from 96-99 then they fixed the issue, sort of, the phase 2 had a different but similar problem any body know when that was fixed, i dont know i know the newer sti motor thats a 2.5 does not have the issue
February 5, 200818 yr I wonder why subaru doesn't offer the 2.2L engine as a cheaper option to the 2.5L on all new cars? It would save them millions on warranty repairs alone.Yes, but that would be admitting to a mistake. For example, let's say you're Coca-Cola, and you introduce a new formulation for Coke, but many people don't like it. Would you go back to making the old stuff...? Uhh, never mind.
February 5, 200818 yr Sorry, guys I'd like to get back on topic. Shame on me, I know but I promised. I checked the orig. intake manifold for the "T" that was mentioned. Sure enough just as OB99W said it connected to the FPR (Fuel Pres. Regulator) So I swapped the lines (the "T" fitting is NOT on the line from the 95 EJ22 that I used). The Map/baro sensor line connected, used my scanner to erase the code, started her up, and No Codes!! I'll just take a minute to thank everyone involved! Maybe we should mention this to other EJ22 swappers. Here is the best I could do when mounted
February 5, 200818 yr [...]No Codes!! I'll just take a minute to thank everyone involved![...] You're welcome, Skip; glad I could contribute to a successful effort (and I'll try to stay more on-topic ).
February 6, 200818 yr So skip, you didn't notice any running differences with it unplugged like that? If it's an automatic, did it shift fine disconnected? I'll just take a minute to thank everyone involved! was that a minute? you already did! Second, a thanks to Gary for mentioning the filter. for real, no problem, that's great it was a simple fix.
February 6, 200818 yr , you didn't notice any running differences with it unplugged like that? It seem to run just fine untill the inspection ran outabout 9 mo. ago. (see below) If it's an automatic, did it shift fine disconnected? I'm sorry, Gary.This question is very hard to answer and does not really belong in this topic as the tranny has a bad drive gear for VSS#2. It is therefore in a "limp mode". No VSS => CEL after so many drive cycles. Readiness monitors are still not set, so no sticker for me in Pee Aye. Again off topic, I am working on a phool the pooter phix and will report in it's own post. Thanks once again for all the help. I hope this entire debacle helps Jules and some one else with the MAP/Baro sensor ordeal.
February 7, 200818 yr Readiness monitors are still not set, so no sticker for me in Pee Aye. Seriously? My '96 2.2l is exempted from that test in NY at least since '96 soobs reset all the I/M's to not ready or not tested every time turned off?
