got another code issue p1702??????
P1702Auto Trans Diagnosis Input Signal Circuit
so i beeen rebuilding transmissions again
and got this code????
i dont know this one
im check 4 wd now
i also got a 0135
but thats o2 and i might have bogarted the o2 in the swap
but i dont "get" this 1702
update
so it has 4wd, allways with bind
put in the fuse and no light but no 4wd either
does not shift out of 1st, does have reverse
no more code after clearing it
im a liitle confused again
normally these things take their clutch and are good
this ones acting like the cyl is bad
but all is new
new clutch pack, cylnoid, gear that was sheared off, so complete tailshaft over hual
trans DID have all gears before
did not have 4wd(broken gear)
Check all your harness connections.
That is the signal that tells the ECU that the car has an automatic transmission.
ok will do, car is an auto
(trans and tcu are out of another car, same year/engine/trim)
so there shouldnt be any funny bussiness going on
car original trans had broken pump
so pulled to rebuild(was not able to)
off to check elec
off to check elec
cleaned and greased all connections
pulled fuse,
still stuck in 4wd and nothin but 1st
are you sure it's only got first gear and isn't just running in limp mode - which would be 3rd? if it's in 1st it's not good for very fast, but 3rd is capable of 60, 70, 80 mph.
was the transmission removed for the job? give us as much background as possible, if it was i would check and make sure the harness is fully seated and none of the pins were bent.
car was purchased with a broken trans(no 4wd, bad clutch set)
i didnt use it becouse the numbers come back as a 92 model???
the car that provided the trans was purchased for its body
i put the trans straight into the first car
and it worked fine but didnt have 4wd
so i pulled it
and pulled the tailshaft, all done on bench
the rear gear was sheared apart
so replaced gear, clutch pack, and 4wd cylnoid,
put tail shaft back on and put trans back in car
the tcu stays with the transmision so its all good there
i now have 4wd, allways with bind, the fuse does work
but does not light up the dash light(might need a bulb)
does not have bind with the fuse in
does not come out of first(top speed 15???)
does have reverse, does not manually shift into 2nd,ect
the first time i put in the trans the tcu was wrong, and it flashed at me
and what not, but it shifted, now it doesnt shift
i checked 2 big connectors, cleaned and greased and reset(click)
plugs seated nicely
i didnt see any bent prongs
thats what i know
hehe..if the tcu doesn't control shifting then what does it do? Sorry what year and model soob was this again?
well my buick doesnt have a tcu
so you dont need one, but i dont know what out tcus do
i would hope they do something
96 legacy l 2.2
Ah ok cool, sorry about that. I have a 2.2L '96 too...here's the troubleshooting procedure for P1702. Rebuilding trans sounds interesting. I haven't even pulled an engine yet.... Godspeed to you in figuring this out!
What MY car was purcased with "broken trans"?
Didn't use what?????????????
What MY was this car?
Which rear gear?
What MY TCU do you have in what MY car?
Do you have ADD?:grin:
no i do not have add
both cars were 96 model years
i do not use the trans that was in the car becouse the part number said it was a 92 model year trans, and it didnt have 4wd
porc thanks
first thing in the mornign and ill run down that list
see what i come up with
so i swaped the TCU and got shifting and AWD back
but now the light is flashing at me again
allways something
allways something
have you checked for torque bind? if so does it go away with the fuse installed? a bad duty c will cause flashing. i would have thought if it was the duty c it would have shown up with the other tcu but who knows.? try a third tcu, maybe 2 out of 3 would be a clue to the cause..
