lumpycam Posted February 15, 2008 Share Posted February 15, 2008 I just finished swapping an ea81 into a ea82 spfi wagon, It is complete and running except for power steering pump.I've heard that the ea81 pump and brackets will work with some modifications.My question is , has anyone done this successfully? If you have , what's involved to make it work? Quote Link to comment Share on other sites More sharing options...
TheYeti Posted February 15, 2008 Share Posted February 15, 2008 You will need to grind the base elbow of the bracket so that it fits with the EA82 SPFI manifold. That is as far as I made it before I traded my wagon for a brat. Quote Link to comment Share on other sites More sharing options...
mcbrat Posted February 15, 2008 Share Posted February 15, 2008 I just finished swapping an ea81 into a ea82 spfi wagon, It is complete and running except for power steering pump.I've heard that the ea81 pump and brackets will work with some modifications.My question is , has anyone done this successfully? If you have , what's involved to make it work? you'll need to either get some fitting adapters, or customize the PS lines, as the fittings are not the same for ea81->ea82 I can't speak to fitting it with SPFI though.... Quote Link to comment Share on other sites More sharing options...
lumpycam Posted February 15, 2008 Author Share Posted February 15, 2008 Thanks for info. O.k. that helps a little , gotta make it work. Can't imagine giving the car back to the ex-girlfriend and telling her "Hey, it runs great but...no AC or pwr str!" Quote Link to comment Share on other sites More sharing options...
Free Range Posted February 16, 2008 Share Posted February 16, 2008 longShot, but the ea81turbo cars have a very simmilar, if not the same pump and mounting location as the ea82's, so that turbo ea81 bracket would do it. Quote Link to comment Share on other sites More sharing options...
Caboobaroo Posted February 16, 2008 Share Posted February 16, 2008 longShot, but the ea81turbo cars have a very simmilar, if not the same pump and mounting location as the ea82's, so that turbo ea81 bracket would do it. Ding ding ding. This is the key. EA81T power steering pump bracket with the EA82 pump on it. The bracket difference between the EA81T and the EA82 is the fact that the pump has to stick out to clear the timing belts where as, the EA81 has none. Quote Link to comment Share on other sites More sharing options...
bratsrus1 Posted February 16, 2008 Share Posted February 16, 2008 Hey Lumpycam This is Jerry, i have a complete set up from a EA81T power steering pump and brackets. I also have the water pump and the crank pully and belt driven fan all of them have double grove pully set up. make me an offer let me know. Thanks Jerry Quote Link to comment Share on other sites More sharing options...
lumpycam Posted February 16, 2008 Author Share Posted February 16, 2008 I'm using an early solid lifter ea81, there are only two bosses on top of block for alternator bracket.Also when you flip the AIC valve it puts it right were the pump would normally be on an ea82.Do the ea81t blocks and the hyd lifter blocks have bosses for the pwr steering bracket? I looked at maybe using ea81 a/c bracket to mount pwr steering pump, not much room between alt and battery though. It looks to me the best shot is to use n/a ea81 pump and brackets, but I don't have any to try. Quote Link to comment Share on other sites More sharing options...
GeneralDisorder Posted February 16, 2008 Share Posted February 16, 2008 EA81 pump and bracket should work. They mount way off to the side. The belt is long, and expensive. Shouldn't be too hard to run some new hoses from the EA82 rack to the EA81 pump. GD Quote Link to comment Share on other sites More sharing options...
mcbrat Posted February 16, 2008 Share Posted February 16, 2008 http://www.ultimatesubaru.org/photos/showphoto.php?photo=4334&cat=530&ppuser=3 Quote Link to comment Share on other sites More sharing options...
lumpycam Posted February 18, 2008 Author Share Posted February 18, 2008 Thanks all for your help! I'm off to find a pump and brackets , I'll keep you posted on progress. Quote Link to comment Share on other sites More sharing options...
