EA82T_4WD Posted March 8, 2008 Share Posted March 8, 2008 Looking for advice on whether this car is a good buy. 94 SVX that needs a new front diff for $1325. I'm hoping to get an idea of how much would this differential cost, as well as potential labor at a shop - I'm seeing diffs from other late model Subarus available online from 50-250 bucks but nothing for "SVX" specifically. Is this something I could/should think about installing myself? Have tools and a bit of experience wrenching on Subaru, but not drivetrain parts yet. Here's the ad in question: http://portland.craigslist.org/clk/car/592673291.html Thanks all. edit: to clarify the car needs FRONT diff, not LSD Quote Link to comment Share on other sites More sharing options...
screwbaru2 Posted March 8, 2008 Share Posted March 8, 2008 I don't know what the job intails but I'd sure find out! It can't be that hard if its a subaru. Soobs are the easiest cars I've ever worked. One of the major reason I stay with em. Also parts availablity make sure you can get the parts. If you call a bone and ask for the parts and they laugh at you, then your probaly sunk. That is a clean and neat looking machine right there. I'd buy it. Of course I'd have to move after my wife saw it! Get in touch with daviegravy he/she is on this site with a 92 SVX Quote Link to comment Share on other sites More sharing options...
1997reduxe Posted March 8, 2008 Share Posted March 8, 2008 wow, that's a nice looking car. i'd want to know how they know that it's the differential, though. (who diagnosed it?) i don't know if it's feasible, but get subaru to look at it if you can. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 8, 2008 Share Posted March 8, 2008 be careful with the SVX, they can be very expensive to maintain. they are great cars and very reliable but spending an entire tax return on one and having no disposable cash might not be the best idea on this. parts can be hard to find, i was looking for an idle controller or TPS for a friend a year ago and couldn't come up with one for a decent price. windshields = $700. wheel bearings and automatic transmission failures are very common with these and are rather expensive fixes. if you get one - install an aftermarket dedicated transmission cooler immediately. they're only $30-$40. good luck with it - they are certainly very cool cars and drive very, very nice! Quote Link to comment Share on other sites More sharing options...
crazyhorse001 Posted March 8, 2008 Share Posted March 8, 2008 If it is the Diff, and I doubt it is, unless the LSD itself is hosed, you can get and swap in new gears without much fuss. It's more likely torque bind from any of 3 sources. 1. TPS bad or mis-adjusted 2. Solenoid C troubles 3. Mis-matched tires The rear diff on a SVX is pretty much bullet-proof The AD says it's the transmission differential. That means the front diff. In the SVX the gears are 3.54:1 they're unique in all the 4eat transmissions. A cost effective swap is the 4.44 gears from the Legacy Outback. You can simply swap in the gears, or the whole trans. Just remember that you need the rear diff as well, to swap the gears into the SVX rear carrier. Quote Link to comment Share on other sites More sharing options...
EA82T_4WD Posted March 9, 2008 Author Share Posted March 9, 2008 Thanks for the advice. I think I'll see if the price drops, and if it gets ridiculously cheap like < 1000 I might pick it up, expect to repair/replace the tranny and install that cooler. Still for 2k it would be a nice car I think. My buddy had one and I remember its stellar handling. Quote Link to comment Share on other sites More sharing options...
Hondasucks Posted March 10, 2008 Share Posted March 10, 2008 I've got a good front diff if you get it, I bought my 92 for $800 with a cooked tranny, 1300 does seem a little steep BUT it is a 94, which is a little rarer than the 92. Check out http://www.subaru-svx.net Quote Link to comment Share on other sites More sharing options...
idosubaru Posted March 10, 2008 Share Posted March 10, 2008 being the front diff i'd just plan on replacing the entire transmission. other EJ transmissions will work if you swap the rear diff to match. that's the easier and not very expensive option. Quote Link to comment Share on other sites More sharing options...
92svxman Posted March 10, 2008 Share Posted March 10, 2008 You can alway replace the tranny with one from another Subaru, Just check out the gearing you want and get the whole driveline for less then repairing the front diff.. The SVX is a great car but is a little slow off the line with 3.454's if you go for 3.90's it would get up to speed faster. There are also 4.11's and 4.44's. A used tranny should be under $500, for the flex plate, tranny, drive shaft, and the rear diff. so they match. Good luck svxman Michael Quote Link to comment Share on other sites More sharing options...
