bad plastic headlights! down!
I have polished with Plasticx, sanded with 1000 grit, and polished again. It works for a while then comes back. Im sure somebody has a better way.
You are then suppost to put on a clear coat of some sort I believe.
Good ole wax works also. I use 1500 grit LOTS of water (running hose while sanding) and car wax after drying.
I just got a set of headlights from the Junkyard that look to be in near new condition. No yellowing at all.
Would it be a wise decision to clearcoat them before installing them to help prevent yellowing in the future?
And will any ole clearcoat work? I got some spray on stuff I used for modeling.
-Brian
i've done this several times and everytime i used clear coat and its never gone back yellow
