April 9, 200818 yr Hi all. Sort of newb here but I liked the "sube family" post Before I start asking for help maybe someone could tell me how to identify my engine type? Like is it an EA81T, or what? And are there specific English, (OK, UK), engine versions? Like I said: Jan 93 Turbo, 1994cc, 196 bhp (maybe not now?), Estate - you call 'em Wagons I believe. I just love this car It's done ca. 185,000 with quite a few bits replaced from scappers, (springs mostly) but it goes like no other car I've ever owned. And I had quite a few over the last 45 years. P.S. How do I include pics in my posts?
April 9, 200818 yr Hey welcome aboard . Just for future reference any postings about this car should be in the newer generation forum since its a legacy. Your engine is the Ej22T, a bullet proof engine as many on here will attest to.
April 9, 200818 yr Jan 93 Turbo, 1994cc EJ 2.0T In N.America we didn't get that motor in a Legacy, we got the 2.2. It's done ca. 185,000 with quite a few bits replaced from scappers Mine is at 307,000 miles. (EJ 2.2T)
April 9, 200818 yr Author Hey. Thanks guys. But a little confused. Is there any way, by examining the engine, I can determine whether it is an EJ 2.0T? Note taken about the posting place - just thought 15 years old to be old BTW, if you haven't a 2.0T in North America, what Turbo models do you have? I note in another post a reference to an XT Turbo Legacy in North America. Ooops nearly forgot to appreciate the welcome. Thanks
April 9, 200818 yr Is there any way, by examining the engine, I can determine whether it is an EJ 2.0T? Well, I'm not quite sure what you mean, there are two versions of the EJ 2.0T, SOHC and DOHC. On the block, at the front looking, behind the oil sensor, there is a raised platform area in the casting, that should have the displacement stamped on it: eg: 1.8EJ 2.0EJ, 2.2EJ, 2.5EJ. I am not sure if there is a turbo designation stamped here too (and it's -11 outside this AM, so I'm not going out to look, at least not right now). if you haven't a 2.0T in North America I didn't say that, I said that that motor was not factory installed in a Legacy body for N. America. Here that motor would be found in the smaller series of cars, ie. Imprezza. XT Turbo Legacy Officially no such car exists. (early turbo Legacy cars here were called "sport sedans")
April 9, 200818 yr 1994cc, it is a 2.0 It is a EJ20T It should be stamped in your block someplace... the EJ20 part. The US Legacy's got the 2.2 liter turbo in their Turbo Legacys. Known as the EJ22T. And Reveen. I dont think the US got any variation of the EJ20. Not until the WRX came over here. The Early impreza's went from 1.8 to 2.2 liter. -Brian
April 9, 200818 yr Author I looked on the block. When I'd brushed off the crud I could clearly see "EJ20". And DOHC also. So thanks for that. Now I can post with more confidence
April 9, 200818 yr Note taken about the posting place - just thought 15 years old to be old that is the common assumption. but Subarus have existed for about 40 years. so 15 is still pretty new. also, pop-riveted to the driver's side strut tower, there's a steel plate with some serial numbers stamped on it. This will have your true engine code, as an EJ20T doesn't really exist, it's just a generic term to reference any 2.0l turbo motor. Your motor should be an EJ20G.
April 9, 200818 yr Author OK. So I've got a teenage car In which case I'd better bone up while it knows everything! I'll check up in the ident plate inside hopefully next week - I have to be away on a job - Peter
