April 17, 200818 yr I am just wonder what the eletronics high lighted in the pic control Thats on the passenger side strut tower
April 17, 200818 yr your pictures take FOREVER to load, why is that? really annoying, can you shrink them and just post them on USMB rather than use photobucket? the bottom solenoid is a switching solenoid, the other is a pressure transducer or sensor. they affect transmission shift points in an automatic and are semi-EGR related as well. other than that i'm not sure.
April 17, 200818 yr Author hey sorry about the pic i just really didn't know any other way of doing. As far as the size i just want them to be clear. Since those wire aren't hooked up then i think i figured the my shifts are off :clap:
April 17, 200818 yr hey sorry about the pic i just really didn't know any other way of doing. As far as the size i just want them to be clear.[...]To find software to reduce an image to the relevant portion, you could do a Google search on "image editing cropping", for example. Here's one way to accomplish the task: http://www.updatexp.com/image-cropping.html EDIT: I used MSPaint as explained in the link above, and saved it as a JPG file. I'll attach it to this post and see how it looks. Further EDIT: There's some loss of detail, but I think it serves the purpose, and the file is much smaller.
April 17, 200818 yr That is the MAP sensor. It affects everything from shift points, to compensating for alltitude. It samples both the Manifold vacume and the atmospheric pressure. It's slightly inportant. nipper
