jelly man Posted May 29, 2008 Share Posted May 29, 2008 I have a 93 impreza with no voltage to the fuel pump. I tried pulling the codes. There were two plugs under the dash near the center that I plugged together. I guess they were the right ones but when I turned the ignition on the check engine just kept on flashing constantly. Any ideas or suggestions? Quote Link to comment Share on other sites More sharing options...
Cougar Posted May 29, 2008 Share Posted May 29, 2008 Have you checked the fuse for the fuel pump and to see if there is voltage getting to the relay? Quote Link to comment Share on other sites More sharing options...
jelly man Posted May 29, 2008 Author Share Posted May 29, 2008 I checked all the fuses under the dash. All had continuity. I don't have a schematic to find which fuse it is. Quote Link to comment Share on other sites More sharing options...
Cougar Posted May 29, 2008 Share Posted May 29, 2008 Fuse 16 should tie to a yellow wire that goes to the fuel pump relay. I would make sure that power is going through the relay contact to the pump. Quote Link to comment Share on other sites More sharing options...
jelly man Posted May 29, 2008 Author Share Posted May 29, 2008 Where is the fuel pump relay? We checked the 3 relays on the fuse block and all worked fine. I really need to know to follow the power. Quote Link to comment Share on other sites More sharing options...
Cougar Posted May 29, 2008 Share Posted May 29, 2008 I think is up under the dash near the steering column. Quote Link to comment Share on other sites More sharing options...
EVOthis Posted May 29, 2008 Share Posted May 29, 2008 yes i believe there is a cluster there of 3 realys (main relay,fuel pump relay, sub fan#2 relay(if you have A/C)....i have chased problems up the wall because subaru decided to mount every other of the 5 A/C/Fan relays under the hood and this one under the dash... ....pick up a haynes manual....very helpful Quote Link to comment Share on other sites More sharing options...
jelly man Posted June 1, 2008 Author Share Posted June 1, 2008 Evidently the impreza has the 3 relays on the fuse block. I checked the wiring and the ECU is definitely flashing continuously in u check mode. I just assume this means a bad ECU. Any other thoughts or ideas? Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 1, 2008 Share Posted June 1, 2008 If the CEL is on you need to count the code sequences. The ECU is most likely fine. You also need to check to see if voltage is getting through the fuel pump relay. Quote Link to comment Share on other sites More sharing options...
jelly man Posted June 1, 2008 Author Share Posted June 1, 2008 Again the ECU is not putting out any codes. It will not do so. All it does is flash the check engine light at a steady rate. No long flashes for tens and no short flashes for the ones. Just flashing at a steady rate. I gave up counting after over thirty flashes. Quote Link to comment Share on other sites More sharing options...
Manarius Posted June 2, 2008 Share Posted June 2, 2008 Back in my 1991 Legacy, there was a connector under the back passenger seat that would tend to melt and cause the fuel pump to not receive voltage. I don't know if the early Impreza suffers some this same problem, but it wouldn't hurt to check. I would also check the connection directly at the pump. The pump should be accessible from the trunk. Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 2, 2008 Share Posted June 2, 2008 Did you remove the test plug connections under the dash or hood and still have the flashing CEL? If not, remove the connections and see if the light goes out. Quote Link to comment Share on other sites More sharing options...
jelly man Posted June 2, 2008 Author Share Posted June 2, 2008 Yes - the light is only flashing when the connectors are joined. It stops when they are unplugged. Quote Link to comment Share on other sites More sharing options...
Cougar Posted June 2, 2008 Share Posted June 2, 2008 Then that may be ok. We need to see if the fuel pump relay is getting voltage next. Quote Link to comment Share on other sites More sharing options...
