ej25 phase II does it have the disty space?
like does a Phase II EJ25 have the cam cover/slot for a distributor?
I am not wanting to use a distributor but a CAS for a DSM for megasuirt and spark.
Not as easy as the 2.2, but it might be doable.
There is a plug at the rear of the head for Camshaft like the 2.2. Pull the cam retainer/rocker carrier assembly off the head and the plug should be free to come out. From there it's just a matter of finding a disty to fit, and a way to bolt it down. Probably require some machining/welding tabs to the head.
thanks that's what I wanted to know.. I saw someone running a DSM CAS on another engine for MS-n-spark and it worked fine... my engine will be here end of the month. I wanted to know if I had cam acces on the back of the head! I may have to weld tabs and that's all good!
IIRC the DOHC ones don't have the place for it....but the SOHC ones might.
it matters not
if I have to I'll run EDIS.
  • 1 month later...
it "could" work on an EJ25 you'd need to grind cam slots and make up an adaptor bracket.
not something I want to try...
