edrach Posted June 6, 2008 Share Posted June 6, 2008 I think I know the answer to this but need a bit of confirmation from others who have tried it before. I want to replace the exhaust system on my other Brat from the y-pipe back to the muffler. Parts are a bit rare for the Brat, but I'm thinking that the parts from an EA81 wagaon ('83, '84) would be the same. Anyone done this and could confirm it? Quote Link to comment Share on other sites More sharing options...
Spiffy Posted June 6, 2008 Share Posted June 6, 2008 I kind of asked the same thing here: http://ultimatesubaru.org/forum/showthread.php?t=88908 that is, if it's the y-pipe you're talking about... seems there are subtle differences with the spacers, but those can be overcome as long as you have spacers, just in case... nobody seemed to mention that a brat y-pipe wouldn't work on a wagon, and vice-versa... however, for the pipe behind the y-pipe I'm not sure if it's a different length... I can measure my wagon later today, if you've still got enough brat exhaust to compare it to... --Spiffy Quote Link to comment Share on other sites More sharing options...
edrach Posted June 6, 2008 Author Share Posted June 6, 2008 Yea, if you can measure it that would be great. I have two Brats and I can compare what you get on the wagon to what I measure on the other Brat. I've got a OEM y-pipe (used of course) that I can install, but I don't have the rest of the system yet and I'm hoping the wagon exhaust interchanges with the Brat. Quote Link to comment Share on other sites More sharing options...
monstaru Posted June 6, 2008 Share Posted June 6, 2008 motion auto carries all of the bits and pieces you need.it depends if you are going stock or not.they carry all walker exhaust products. i have switched ea82 y-pipes(a little bigger) onto ea81 cars,have swapped between wagon and brat as well.mounting is basically the same except for like one hook, and it is doable if you bend the hook(use mapp torch to heat up).cheers, brian Quote Link to comment Share on other sites More sharing options...
samneric Posted June 6, 2008 Share Posted June 6, 2008 I need the intermediate pipe myself. Tried googling a few variations of "motion auto" but came up blank Did find this though... http://www.exhaustwarehouse.com/index.cfm?display=prod_info_list.cfm&id=1769&unitprice=57.498 Steve Quote Link to comment Share on other sites More sharing options...
MilesFox Posted June 6, 2008 Share Posted June 6, 2008 the only variations with exhausts is the mid pipe between 2wd and 4wd. an ea82 y-pipe will work also, but it will hang lower then the ea81 with the spacer plates on the exhaust ports. a full ea82 exhaust should all fit the same. otherwise there should be no difference between any ea81 y pipe, except for those that have an o2 sensor. Quote Link to comment Share on other sites More sharing options...
Spiffy Posted June 7, 2008 Share Posted June 7, 2008 my wagon's mid-pipe from flange to flange was about 60"... --Spiffy Quote Link to comment Share on other sites More sharing options...
samneric Posted June 7, 2008 Share Posted June 7, 2008 my wagon's mid-pipe from flange to flange was about 60"... --Spiffy Cheers Spiff. Oh, following the line of the exhaust or "As the crow flies" ? Steve Quote Link to comment Share on other sites More sharing options...
Spiffy Posted June 7, 2008 Share Posted June 7, 2008 Oh, following the line of the exhaust or "As the crow flies" ? as the crow flies... car was on the ground and I didn't have a helper... so that's my best estimation in a straight line from flange to flange... --Spiffy Quote Link to comment Share on other sites More sharing options...
