Replacing Cam Position Sensor
I am going to replace the CMP sensor because when I place a little pressure on it while the engine is running, it dies and won't restart. I have to play around with it a little to get the car to start again.
Is this easy to change in a 96 Legacy sedan? A Chilton says to remove timing belt, cam sprocket and covers before removing the sensor. Is it really that much to do? It looks like just a retaining bolt, pull and replace. Is there a DIY that I can reference before getting my hands dirty?
Jay
you should have the 2.2 so really it is that easy. undo bolt replace. on my 2.5 if i remember right it helps to pull the valve covers.
worse case scenario would be pulling the valve cover, none of this pull timing cover and gear crap.
+1^ extremely simple to replace i think its either a 10mm or a 12mm bolt and connector and wola.....how many miles are on the car?
yep!
A Chilton
eeewwww!!!
no.
that's it! don't you like good news?!
not really anything to it, like you already figured out. it would be almost as complicated as a DIY for filling your water glass. don't sweat it, just ignore your Chiltonofcrap.
Hey, That was my question on that Wiki - nah, not really (Subaru with a V4?).
Thank for all the feedback. I have more confidence in myself to replace this. Eventhough the car has 145K miles I still want to keep her alive.
I know about the Chilton and that is why I questioned it here. But $1 @ garage sale sounded like a bargain to me. Guess I'm a little cheap to order the $75 CD manual.
I just received the part and will probably try the replacement this weekend between all the 4th BBQs.
You all have a great 4th of July celebration and I'll let you know how this went afterwards.
jay
  • 2 weeks later...
Ok - that was a pathetically easy replacement. The head bolt of this 2.2L engine looks like it is in the way, but a twist of the sensor gave a little more clearance so to tilt it out. The new one went in as the old one came out. Torqued the retaining bolt to 36 ft-lbs.
As I removed the electrical connector, I noticed that one of the contacts was bent a little. Maybe this was my problem in the first place and I now have a used replacement part. Oh well it wasn't a overly priced part. I'm glad the car is back in order.
It seems to run a little better. I can't imagine that the signal from this sensor is directly amplified to provide spark plug juice. Ah - its probably psychological.
:burnout:
jay
Ok - that was a pathetically easy replacement.[...]
Yeah!:clap: Chilton's can make an easy job seem overly complicated, but they also sometimes do the reverse. There's nothing quite like taking something apart only to find that the next step requires a tool you don't have handy, or having a procedure sound much less complicated than it is. It reminds me of a joke a friend tells about home improvement books; the project is adding a second story to a house -- first step, "Remove roof and temporarily set aside." :)
I can't imagine that the signal from this sensor is directly amplified to provide spark plug juice.[...]
Not directly, but it's used to trigger timing of control circuitry.
