noordhorn Posted January 8, 2009 Share Posted January 8, 2009 I'm new here. If I put a used engine, that came out of an automatic car, into my standard shift car, does that change anything as far as the engine computer? Why do the cars with different transmissions have different computers? Quote Link to comment Share on other sites More sharing options...
nipper Posted January 8, 2009 Share Posted January 8, 2009 They have differnt computers because th computers do differnt things. In an auto it needs to know what gear the car is in, it needs a torque reading sometimes, and it interacts with the TCU to shut off/modify/etc cylinder firing during shifts. Thats just to name a few. No reason to put a puter in a car that doesnt need to know these things, as it costs money. I cant give you an absolute answer (as I dont remeber it) but someone else will. nipper Quote Link to comment Share on other sites More sharing options...
[HTi]Johnson Posted January 10, 2009 Share Posted January 10, 2009 If you just put the engine in you'll be fine. If your putting the engine in the car with a standard transmission, just use the intake and sensors from that car...as for the most part the engines are the same. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 11, 2009 Share Posted January 11, 2009 If I put a used engine, that came out of an automatic car, into my standard shift car, does that change anything as far as the engine computer? what may apply to one make, model, year, engine, trans - may not apply to others. some are much easier to tackle than others. it's like saying "can i swap wheels"? so you would need to ask about a specific year, model, and engine to get an answer. They have differnt computers because th computers do differnt things. In an auto it needs to know what gear the car is in, it needs a torque reading sometimes, and it interacts with the TCU to shut off/modify/etc cylinder firing during shifts. Thats just to name a few. No reason to put a puter in a car that doesnt need to know these things, as it costs money. often automatic and manual engines interchange just fine (been there, done that). i've even swapped ECU's from automatic and manual trans equipped subarus. i'm not saying it can always be done, but i've done it. i ran a 6 cylinder on a 4 cylinder ECU once, that was pretty awesome. it was ugly and not *driveable*, but i just tried it for kicks. i couldn't believe the car actually ran and drove. i think some ECU's can handle either and use an identifier pin to specify what trans. Quote Link to comment Share on other sites More sharing options...
nipper Posted January 11, 2009 Share Posted January 11, 2009 often automatic and manual engines interchange just fine (been there, done that). i've even swapped ECU's from automatic and manual trans equipped subarus. i'm not saying it can always be done, but i've done it. Just explaining the reasons why they have different puters . I figured someone who has swapped them can answer better then me. nipper Quote Link to comment Share on other sites More sharing options...
idosubaru Posted January 11, 2009 Share Posted January 11, 2009 Just explaining the reasons why they have different puters . I figured someone right on hot diggity, i was being that *someone*. someone else will chime in with more! Quote Link to comment Share on other sites More sharing options...
