Turbo Clutch in 2 a Non-Turbo 4x4?
Just picked up an OEM quality clutch for a 4x4 Turbo car for cheap. Will this bolt in to my Non-Turbo 4x4 GL? If it does fit will the pedal feel noticably stiffer? Talking about an EA-82 D/R 4x4 here. Thanks.
The last time I looked at a Subaru parts book, EA82 4wd and EA82T 4wd uses the same disk and pressure plate.
The Turbo and 4WD clutches are the same as I recall. It's the XT6 clutch and flywheel that is stiffer....
Should be exactly the same as what you have.
That's exactly what I wanted to hear. Thanks for the replies.
