Help with a weber?? ( PICS !!!)
How do i know what weber carb i have, my dad bought it a while ago and doesnt remeber so i dont know which i have, and is there a thread that has possibly a step by step or picture of intalling one also?
Thanks
SS
Edited by GREENSUBIE
To Know which one you Have, Read it... it should say, but I Suggest you to Post Pics of it here, so we can Help you in a Better Way.
There are some Good Threads about how to Swap a Weber Carb in a Subie, I Wrote one Plenty of Pics & Ideas... Click on my Avatar to Reach my "Public Profile" Page, there is a List of some of my Writeups.
I Hope that can Help you.
Kind Regards & Good Luck!
Alright so I took pictures. i installed the weber and now there are a lot of loose ends. first of all here is a picture of the weber i have could someone tell me which it is, or some info on it.
What to do with these loose ends?
Sorry pictures arent bigger
Thanks
SS
That is a 32/36 dgev and it should be stamped at the base of the carb.
For the most part, you should cap the loose ends. Your picture is kind of small, I can't really see what you are pointing out.It looks like you have the timing advance hooked up, It doesn't look live you have the pcv and valve cover/air cleaner hoses rigged up. Go to post #27 in this thread:
http://www.ultimatesubaru.org/forum/showthread.php?t=95483
and rig them like the diagram McBrat drew up.
If you post a bigger pic I could be more helpful.
bigger is better lright :banana:
well these were huge. but after i put them on here they are like tiny still but i tryed
Remove the lines and cap all that stuff on the passenger side.
Remove the cap on Vac Advance pot, and connect a line from the carb to it
On the drivers side, that looks like it's the fuel return line. I'd use it.
There is tons of info on these here, SEARCH SEARCH SEARCH! :)
Edited by Greenley
