March 11, 200917 yr I brought a 95 Legacy L wagon on the 6th of this month and I knew the car had the Hill holder but I see it has been disconnected.. since I'm not good on hills yet and tired to use the ebrake way how can I connect this back? It seem the cable goes on the plate but how? Here is a picture
March 11, 200917 yr See the hole with the notch in it? Rotate the plate clockwise, until the cable end can slip into the hole sideways, feeding the cable through the notch. Lay the cable around the groove. Adjust the nut on the other end so that the hill holder cable has just a hair of slack on it when the clutch pedal/fork is in the released position.
March 11, 200917 yr Author See the hole with the notch in it? Rotate the plate clockwise, until the cable end can slip into the hole sideways, feeding the cable through the notch. Lay the cable around the groove. Adjust the nut on the other end so that the hill holder cable has just a hair of slack on it when the clutch pedal/fork is in the released position. crap I was hoping you would not say clockwise.. It's hard as heck since the cable does not have much slack at all.. what you see in the picture is as far as it will go out at least.. How I was trying to do it when I finally got it around enough to slip the cable in I just tried to push it down into the hole but only half of the lower part went in until it popped out again. *EDIT I think I got it.. I had a helper press the brake and clutch should anything move? I saw the slack being taken up but I'm not sure if the plate should move or not.. Edited March 11, 200917 yr by 1-3-2-4
March 11, 200917 yr No no no thats not it. Do you have a bicycle with hand gbreaks around to look at. The but end of the cable sits in the both holes in the cam (roataion arm) on the hill holder. They way you have it the hill holder will drag the brakes and snap the cable. Loosen the hill holder cable at the clutch fork to get slack. nipper
March 11, 200917 yr Author so it should stand up between the two holes? I don't have a bike to look up
March 11, 200917 yr so it should stand up between the two holes? I don't have a bike to look up yes, you should just see the top of the pin when installed correctly.
March 11, 200917 yr Look at a neighbors http://www.bikewebsite.com/bicycle-bra2.htm look at the second picture and see how the barrel of the cable sits in the hole. nipper
March 11, 200917 yr I should elaborate, take the cable and bring it around so that the pin slips into the hole, then take the cable and route it through that open part in the cam and feed cable around the cam the way you have it now. But the pin needs to be up and down, not the way it is sitting.
March 11, 200917 yr Wow nipper, you are stealth, how do you do that while showing offline. (sorry for the highjack)
March 11, 200917 yr i am sneaky, stealthy and one with the universe, as i am the wind MUHAHAHAHA that and i have the hidden box thingy set in my profile.
March 11, 200917 yr i am sneaky, stealthy and one with the universe, as i am the wind MUHAHAHAHA that and i have the hidden box thingy set in my profile. OOOOOOOOOOOOOOOOOO:lol:
March 12, 200917 yr you can also look under the hood where the throttle cable connects to the throttle body. if your car has cruise, there will be a pair of them.
March 12, 200917 yr They way you have it the hill holder will drag the brakes and snap the cable. Loosen the hill holder cable at the clutch fork to get slack. Only if he's driving uphill. LOL
March 16, 200917 yr Author the brakes don't drag since the cable is not really being pulled at all how it's connected.
March 16, 200917 yr the brakes don't drag since the cable is not really being pulled at all how it's connected. Also the hillholder doesn't generate any brake pressure. It only locks pressure from the Master cylinder after the brakes are released.
