AWD and Single Range
Just curious if theres any type of difference in the drivetrain between these 2 types of trannys. Other then the obvious please.
So whats the obvious? Are you talking about the FT4WD EA82 vs PT4WD EA82 5sp's? They are both the same length so take the same shifter and propshaft. One has vac diaphragm to operate the 4wd gear the other to operate the locking diff. The way to tell these apart are the diaphragm cable on the PT4WD goes up high on the rear casing while the FT4WD one is down lower. They take the same clutch plate. Then theres diff ratios. Both came in either 3.7 or 3.9 (although I think the US PT4WD 5sp only ever came in 3.9). If the FT4WD S/R box is a 3.9 it came from an XT6.
I guess what im asking is that. Is the internal ratios the same from a single range and a dual range.
Yoke doke dokie im an idiot. I said it wrong. Gear differences between a 5 speed awd and a 5speed single range tranny.
AWD transmissions generally ARE single range. Unless you get a european dual range AWD. Never produced them for the states though.
Gear ratios are all over the map. Different years of the same transmissions had different ratio's. It's all about what the transmission came from. If you don't know exactly what it's from then the only way to check is to verify them manually or split the tranny.
If you are talking about actual GEAR ratios (1st, 2nd, 3rd..etc) then yes, for the most part the older PT boxes nad the newer AWD boxes have the same gearsets.
Final drive ratios are all over the map.
so then what allows an awd to be engaged all the time but it is recomended to only engage the 4wd when slippery road conditions.
AWD uses a diferential on the pinion shaft. Splitting the drive between front and back like a diff would side to side on an axle.
Older boxes just had a collar that locked the front and rear drive toghether.
so single range is better then awd
No. Not in my opinion.
The improvement in traction under ALL road conditions out weighs any supposed 4wd advantage.
I have been wheeling with a couple AWD lifted Legacies, and they have done just as well if not better than the Part time 4wd Subarus.
Unless you are building a strict rock crawler subaru that won't see the street, you are WAY better off with the AWD.
Heres how it started my thinking. Ive been thinking EJ swap alot lately because the money its going to take to get my ea82 sealed and good parts on it is silly on a 200k motor. So i was thinking if i do this i might as well swap the tranny to the legacy tranny as well. And thats where the whole which is the better one to have thing came into play. I have the push button single range in my car and if i went legacy i would get an awd tranny. Sooo hence my delema.
For what you need the car for, you will be way happier with AWD.
Plus to keep you're S/R you'd need an adapter plate.
you MAY need to have you're driveline shortened. The AWD box is little longer
i know i need to look up ej swap but real quick, can i retain the same axels and the 4 lug setup.
You can keep you're hubs, but you will need to get some 25spline turbo axles.
OR.....alternately you could split the AWD case, and install the 23 spline stubs instead of the 25 spline.
Prolly easier to get turbo axles
