DOOR switch swap? '78 BRAT
will a DOOR switch from something NEWER work?
LEFT side busted, and corodded
RIGHT side flaky, but works and controlls do-me lamp
Those are the same animal for many many years from like 1972 thru 1994 at the very least.
NOT TRUE!!
the '78 BRAT and '84 BRAT use the ROUND switch NO screw
gen 3 uses OVAL switch WITH screw
gen 3 OVAL switch WITH screw can be used after enlarging hole 16.25mm? 5/8 + reamer!, drilling hole for screw, and splicing wires :-\
atleast changing switches is easier now with newer parts :banana:
