January 19, 200422 yr Has anyone ever attempted to make one for the EA82T? If not, and even if so, I am going to make one. I had a factory one fall apart on me, and it looks like its about 1 inch pipe. What a work art to reduce performance. Tips? Suggestions? Past experience?
January 19, 200422 yr For optimum performance you will want equidistant runners like the ones seen in this link > http://www.syms.jp/products/impreza/gc/ex.html Although anything will be an improvement. Josh
January 19, 200422 yr I went to get a up pipe fabricated when I needed to replace mine a while back. the guy I talked to said he was more than willing to take my money but told me that the up pipe is restrictive like that to keep velocity up going into the turbo. he did say that if I was going with a larger turbo then he could see why I would want to go bigger. I put a stock pipe on and will keep it that way untill I go bigger. I now have a means to do some fabrication at home so when I do build a up pipe/down pipe combo I have a few theorys. I would order some mandrel bent tubing. preferably stainless 1.5 or 1.75 and cut and weld with a engine block as a jig. I would also use heat wrap to keep it hot going into the turbo as that is supposed to help.
January 19, 200422 yr Author Email sent to both. rallyruss: i know that theory for low speed power...but it really really makes the engien suffer at the high end, which is where these engines should really be making the power. Its fine for the average street driver, aka non perfomance minded "normal" person, but for some one like me, who is searching for power power power...seriously, look at the peak TQ, 2800 RPM on the turbos. Thats pretty low. The EJ engines have it around 4000. Granted our HP is up there, 4800, and then 5200 from 87+. The TQ drops of past 2800, I would like to move it to the 3000-4000 range, and push those HP figures up as well, not the RPM way, but just increase the figures. That and a DP, I am sure that we would pick up 10-15 HP alone from those mods. I do have the parts to make a Jig (extra turbo, heads, block, engine crossmember)...its jsut that I dont have the time, and I dont ahve a welder. I can get the pipe! Thats about it.
January 19, 200422 yr I think a WRX TD04 turbo charger would do well on these engines. They will flow enough air, although may be a bit laggy under 3.5K. They're up for grabs on Ebay.com. (I bougt a new one and a 1500mi used one in one sale for 300 US$ a while back)
January 19, 200422 yr Author Yep. Ive been looking for one, and a stock WRX intercooler as well....and Ive been looking for a Downpip for one. But then again...with an adapter plate...and a complete EJ20....
January 19, 200422 yr WJM, I didnt say not to do it. I am just shareing what little I know. by all means go for it an and let us know how it runs. I should have also mentioned that I am running a modified down pipe on the RX and a subespeed one on thw wagon. they both help performance a good bit.
January 20, 200422 yr Author Yes indeedy. Ive been searching fora good while for a turbo and IC. That DP i made is kinda killer. Too much flow on the little turbo tho. Boost creep. I had a thread about that. didnt you chime in?
January 20, 200422 yr To add a bigger turbo to your EA82 you will need flanges for mounting and new downpipe as well. The EJ cross over will not work as it is a dual port exhaust vs single port exhaust. Ideally you want your restriction/backpressure before the turbo with almost zero backpressure after the turbo.
January 20, 200422 yr Author I know that about the mounting. The means of zero back pressure behind the turbo, i know that. Now...before the turbo...thats where I have not gone before. I was thinking...make the pipes from each side the same size as the actual port...then size it down at the "Y" to the turbo. Also.......massive idea I have had for a while about reducing turbo lag for large turbos....Jet engine exhaust nozzle. hehehehehe.
January 20, 200422 yr im not really sure that theres alot of power lost in our crossovers... its a catless unit, but maybe a slightly larger diameter wouldnt be too bad of an idea however ive heard the same thing that rallyruss said.
