April 9, 200917 yr my front U joint at the trans output has a large amount of play that is causing a bad vibration at highway speeds. any tips and tricks for replacing this U joint? I have never done one before nor really even heard of one wearing out on a subaru.
April 9, 200917 yr I dont believe you can replace the u joint....they are a non-serviceable item in subarus (no grease fittings or anything so they wear out)..Time to get another driveshaft....at least this is the way it is for the later models say 95-up...Id bet its the same for the early legacies also...
April 9, 200917 yr Author yep did a bit more reading and found that out. awesome freakin design subaru. going to pull one from a dudes parts car in the dark tonight.
April 9, 200917 yr lol...good luck...i would go to a u pull it yard and try and find a low mileage car to grab it out of...I know subaru wants like $700 for some of the newer ones...
April 11, 200916 yr for most folks just get a used shaft. they're so cheap and easy to find you're better off getting two than doing any other option. CHANGE IT NOW. problems at the front of the shaft can break and end up shattering the rear housing of your transmission. then you're in for a really fun job. this can and has happened (even to at least one board member here), i even saw the car today! they are replaceable but that's not normally the best option for most folks. more info on that here if you're interested. some folks, including myself, have done it and replaced them with replaceable/regreaseable joints.
April 28, 200916 yr Check the U Joint. When mine failed in December it cracked off the rear transmission case. Don't let it go much longer at all.
April 29, 200916 yr my front U joint at the trans output has a large amount of play that is causing a bad vibration at highway speeds. any tips and tricks for replacing this U joint? I have never done one before nor really even heard of one wearing out on a subaru. They wear out I am on my fourth one. Always the front U- joint that went bad in mine. I have replaced with one used and two new. But this Subaru has 400,100 miles on it and is used for stop and go Postal del. for the last 13 years. Edited April 29, 200916 yr by tcspeer
April 29, 200916 yr Driveshafts can be rebuilt by a shop that specializes in this. We send them out at the dealer all the time. I think ours go out to Greeley but I dont know for sure. I can PM you back tomorrow if you want to know where. I think its around 250 for one and they redo the u joints and the carrier bearing. Heres another place in Denver:+ http://www.coloradodriveshaft.com/
