April 12, 200917 yr Is that bugger really under the intake manifold?!?!?!? I got one to do a PM, but after noting its likely position, I'll be a monkey's uncle if I'm pulling the intake for it!
April 12, 200917 yr Is that bugger really under the intake manifold?!?!?!? no, it's where the lower rad hose bolts yo the engine. what model & year, 60 chevy pickup?
April 13, 200917 yr It is on the drivers side lower radiator hose right below the timing belt plastic. You should be able to replace it in under 10 minutes tops.
April 13, 200917 yr If possible I'd position the car in the best position to burp it after you re-add the coolant.
April 15, 200916 yr Author D'OH! I was looking topside and saw what appeared to be a T-stat housing. I'll drop the belly pan and peek again. Yes, I got factory parts. I ought to be used to wasting money; my other car is an Oldsmobile!
