April 24, 200917 yr looking for advice notice my image, i have filed the mating surface quite a bit, and am worried about leaks in the future if it corrodes more also the throttle body area hose connector is no good what would you do, replace the mafifold or run form a gasket on the surfaces and hope that tube never rusts off?
April 24, 200917 yr Personally...I wouldnt run the risk of that thing breaking....or causing leaks because you will be right back there fixing it...I would buy a new one or a good used one....Fix It Right The First Time....
April 25, 200917 yr Author Is it often they rust like that? I am now worried about my car if you change you coolant often, no. this one died from neglect.
