May 10, 200916 yr Anyone tried something like these: http://cgi.ebay.com/ebaymotors/80-81-82-83-84-85-86-87-Subaru-Standard-HEAD-LIGHTS_W0QQitemZ120410333290QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item1c0903e06a&_trksid=p4506.c0.m245&_trkparms=72%3A1171%7C65%3A12%7C39%3A1%7C240%3A1318 http://cgi.ebay.com/ebaymotors/80-81-82-83-84-85-86-87-Subaru-Standard-HEAD-LIGHTS_W0QQitemZ120410333290QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item1c0903e06a&_trksid=p4506.c0.m245&_trkparms=72%3A1171%7C65%3A12%7C39%3A1%7C240%3A1318 Considering the wiring remains the same I wonder if there would really be any improvement at all. Plus you never can tell with alot of the ebay crap, sometimes you get what you pay for. But these did look cool.
May 10, 200916 yr Too bad they don't have any lights for the newer cars. Some issues I have to disagree with: I don't think these are the actual xenon bulbs which require significant different power. They look like quartz halogen bulbs with xenon gas as the halogen gas filler. If they are only drawing the current for the lower wattage (normal for quartz halogen), I don't see how they are getting the higher wattage light output. Looks like a bit of a scam to me. They do look cool however; and they are cheap enough to try if you like.
May 10, 200916 yr Author Agreed they are calling them "HID" but the kit doesnt seem to include any ballasts. But the kit is cheap enough to try to play with but something tells me Ill be going from dull yucky yellow to dull get me a ticket blue.
May 11, 200916 yr I have a set of the round STD headlights that came with a conversion kit from Monstaru. They seem to work great, they are much brighter than stock that's for sure, and they aren't sealed beam so you can change the actual bulb
May 11, 200916 yr you can buy different wattage bulbs ed.defenitely not hid or =xenon. the ones i sold to bratman were a little different .but , same idea for sure. you can get 100 watt bulbs for that setup.pretty damn bright actually.they work well if'n you are willing to spend the dough on the bulbs.cheers, brian
May 11, 200916 yr those ebay lights arent very good, the beam pattern is pretty bad. stick with a name brand like hella or cibie, and make sure you get them in E codes, NOT DOT.
May 11, 200916 yr Agreed they are calling them "HID" but the kit doesnt seem to include any ballasts. But the kit is cheap enough to try to play with but something tells me Ill be going from dull yucky yellow to dull get me a ticket blue. however if you put bright bulbs in them they would blind everyone they dont have the correct reflector these or equilivant will work http://www.amazon.com/Hella-Halogen-Replacement-Headlight-Standard/dp/B000FKIURK
May 11, 200916 yr Author The did say they were euro lights. Those hella's are a big step up in price. I really dont need them I was just curious. The other thing is is there are about 30+ different sellers on ebay peddling these kits. Whats the difference between them, other than price, I wonder... http://cgi.ebay.com/ebaymotors/7-H6024-6014-H4-LHT-EURO-CONVERSION-HEADLIGHTS-KIT_W0QQitemZ270321331385QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3ef0682cb9&_trksid=p3911.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318
May 11, 200916 yr Whats the difference between them, other than price, I wonder... Which factory in China ripped off the design:confused: One thing to keep in mind is that if you do the H4 conversion you will burn out the switch and wiring if you don't also do the relay conversion. These bulbs draw a ton more power.
May 11, 200916 yr The did say they were euro lights. Those hella's are a big step up in price. I really dont need them I was just curious. The other thing is is there are about 30+ different sellers on ebay peddling these kits. Whats the difference between them, other than price, I wonder...http://cgi.ebay.com/ebaymotors/7-H6024-6014-H4-LHT-EURO-CONVERSION-HEADLIGHTS-KIT_W0QQitemZ270321331385QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item3ef0682cb9&_trksid=p3911.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318 those are a large step up from the ones in the first post. are those Autopals? anyway the better ones can handle the heat from more powerful bulbs.
May 11, 200916 yr Which factory in China ripped off the design:confused: One thing to keep in mind is that if you do the H4 conversion you will burn out the switch and wiring if you don't also do the relay conversion. These bulbs draw a ton more power. a good idea anyway, any voltage drop makes for a lot of dimmness.
May 12, 200916 yr Author They claim to be 60/55watt, that should be in range of stock. Weather or not the stock wiring can handle it, it probably would, but I doubt they'll be much brighter without a rewiring. I bet the stock lamps would be a step or 2 brighter with better wiring. I was looking for simple plug n play cheapo fun.
