axel Posted May 19, 2009 Share Posted May 19, 2009 The crush type drain plug washers that are generally used aren't readily available around here. Is there any problem using those flat ones instead? Leakage, for example. Quote Link to comment Share on other sites More sharing options...
shortskoolbus Posted May 19, 2009 Share Posted May 19, 2009 well i think you run the risk over having to over torque it to prevent leaking potentially damaging the threads. but in general it should be OK. you can order them online from the dealership, though you'll pay more in shipping than you do for the washers. what's your location? no dealership near by? Quote Link to comment Share on other sites More sharing options...
nipper Posted May 19, 2009 Share Posted May 19, 2009 I reused mine for ten years till I fould out you werent supposed to. nipper Quote Link to comment Share on other sites More sharing options...
nipper Posted May 19, 2009 Share Posted May 19, 2009 http://www.ultimatesubaru.org/forum/showthread.php?t=98955&page=2&highlight=washers Quote Link to comment Share on other sites More sharing options...
johnceggleston Posted May 26, 2009 Share Posted May 26, 2009 The crush type drain plug washers that are generally used aren't readily available around here.Is there any problem using those flat ones instead? Leakage, for example. axel, you need to go into "user cp" tab above and change your settings so you can receive private messages. or send me a private message with other contact info. i have the washers you want. thanks, john Quote Link to comment Share on other sites More sharing options...
