May 24, 200916 yr If i were to go to a junk yard and find a spfi system for my 85 brat what would the junkyard likely charge me? would i need any other parts?
May 24, 200916 yr Hi This is Jerry, done that on my 80 hatchbrat it was to much work to install. Now i have a 2.2 impreza engine in it alot simpler to install and more power. There are 2 more things you need to install on your brat #1 the 5 speed dual range tranny and the other is rear disc brakes after that have fun driving your brat. Thanks Jerry
May 24, 200916 yr I dont know how complicated the spfi conversion is compared with an ej swap but i can tell you the ej is better. Better power, better torque, better aftermarket following. If your going to dig into it do the ej. I like my spfi fuel injection but i to am wanting to go ej. I understand the hardest part about the ej is doing the wire harness but if you go spfi your going to need a computer also.
May 24, 200916 yr The EJ swap is considerably more expensive and requires the ability to haul/move/lift a new engine into place. It is not the answer for a lot of folks. While I agree that it's an excelent option to have, it is not the *right* option for most people. In these economic times it is especially useful to have the option of a bolt-on fuel and ignition system that can be had for a reasonable price. The SPFI is the answer to those that are fine with the overall power and economy of their engine, but have issues with the factory Hitachi carburetor - a new (rebuilt) replacement of which is more expensive than the components for the SPFI swap. As for what parts you need - those are listed in my conversion write up. Pricing varies widely among yards, but expect to spend around $200 for the used parts and probably a bit more for the bits and peices you need to install it. All-in it's aound half the price of a new Weber generally. GD
May 25, 200916 yr Author you are the man gd, thanks for the advice. Since i am still in decent shape with my current carb, im gonna be patient and keep an eye out for a subaru at the local auctions and part out the rest of it.
May 25, 200916 yr Someone else might have the goods for $100 or less; go thru GD's writeup and post an ad in the Wanted section... good luck!
