May 28, 200916 yr My starter on my EA-81 has crapped out on me. I checked all the lines and I am getting full voltage to the solenoid and starter but the solenoid will not push the gear all the way to the ring gear, even when it is out of the bell housing. Does anyone know where I can get a replacement?
May 28, 200916 yr My starter on my EA-81 has crapped out on me. I checked all the lines and I am getting full voltage to the solenoid and starter but the solenoid will not push the gear all the way to the ring gear, even when it is out of the bell housing. Does anyone know where I can get a replacement? should be able to get one at any parts store, or maybe someone will have a used one they would sell
May 29, 200916 yr Full voltage does NOT mean full current. You may still not be passing enough to get it going. The starters are easy to dissasemble and clean the contacts, replace the brushes, etc. But your problem is more likely to be the ignition switch/harness or the battery cables. As far as replacements - Subaru (as far as I know) still hasn't changed their starter design. EA81, EA82, EJ22, and EJ25 are all the same up to at least the late 90's - I know from experience. The really new stuff might be different but I suspect it isn't. GD
May 30, 200916 yr As far as replacements - Subaru (as far as I know) still hasn't changed their starter design. EA81, EA82, EJ22, and EJ25 are all the same up to at least the late 90's - I know from experience. The really new stuff might be different but I suspect it isn't. GD Starters from impreza era cars bolt up to ea81s? I didn't know that. very cool.
May 30, 200916 yr I've had this happen on just about every subaru I've owned. I just replaced the starter with a used one for $25 and it was all better, but you could probably also take it apart and clean the contacts inside and put new brushes in the motor (mine continued to click loudly, but the motor did not turn). Superrupair is where I get the used ones. Z
May 30, 200916 yr Also, it is fairly common for the start position of the ignition switch to stop working -- I've had that happen on three subarus too... my Justy has that problem now. I need to put in a pushbutton switch to start it (or get a new ignition switch, I guess..... )
