Current Head Bolt tightening procedure-What is the Lastest procedure?
I have read through past threads and there seems to be several threads on the Cylinder head bolt tightening/torquing procedure.
Before starting this job I would appreciate as much feedback as I can get, but only relating to the EJ25. If your not sure, don't post.
I have a phase 1 EJ25; year 98; DOHC.
I believe both the Chiltons/Haynes manuals are incorrect in step 4 which states loosen them an additional 180 deg (this the the prior step 3 which also states to loosen them 180 deg (that would be 360 deg total), which wouldn't make any sense.
The replacement gasket is the Subaru OEM gasket set (3rd generation gaskets).
Again, I am looking for the latest instructions. If you do post, please help me and other readers by posting the literature source, and date.
Thanks:confused:
I have done several of these in the past year and this sequence is verified by a subaru tech.
Tighten all bolts in sequence to 21 ft-lbs
tighten to 51 ft-lbs
Loosen all 180 degrees
Tighten bolts 1 & 2 to 25 ft-lbs
tighten bolts 3-6 to 11 ft-lbs
tighten all 90 degrees
Remember to torque in proper sequence and then loosen in reverse order.
Good luck
Good luck
Can I verify is that for an EJ25?
  • 11 months later...
Good luck
Ah, the joys of seating the heads... and some of them made the craziest of CREAKS when tightening them...
Here are a few pics of my heads, marked, and torqued...
#1 & #3 Torqued, adjusted, and marked
#2 & #4 Torqued, adjusted, and marked
Oh yeah and when I removed my head bolts some looked a bit rough and I placed them back in the holes each came from... I don't know if that matters. You should be able to reuse your bolts unless there was some crazy damage...
Edited by 99ImprezaOSport
Yeah, that is a misprint in the haynes and chiltons. Only one loosening of 180 deg. is needed. Doing a second 180 won't really hurt anything, except it will leave the head so loose....i'd be afraid the new gasket could get shifted. That would defeat the whole purpose of the initial "squeeze" of torquing them.
They probably got mixed up by the tighten 90, then repeat.
The proceedure mdjdc is correct.
  • 8 months later...
tighten in sequence to 21 ft-lbs then to 51 ft-lbs. Back them off in reverse order 180 degrees. Now tighten bolts 1 and 2 to 25 ft-lbs and 3-6 to 11 ft-lbs. In sequence tighten all bolts 90 degrees and then another 90 degrees. You are done. When doing the degree tightening do it in two steps.
The bolt tightening sequence is 3 1 5
6 2 4
If you need any other help call me at 804-393-0516
Mike
I'm at work prob can't call till its too lat to call east coast people, do the numbers start at the top front bolt, then work to the back and then the bottom?
yes, they look like this on the head.
3 1 5
6 2 4
it does not matter which end , 3 or 5 is the front. start in the middle and then the corners.
Greetings from LaConner
Call Tony at Skagit Subaru 757-2000 service dept.
He is a good person and will get you the right info for your subaru
You want to us the new head gaskets with the part number ending in 0111
These HGs fix the blown head gasket problems on the EJ25DOHC.
I have known Tony for many years and he knows Subaru's
You can tell him his Alaskan friend with the Ford GT said hi.
