head light trouble
HELP!!!! I have a 89 GL, my passenger side head light is very dim I checked the bulb, its okay. It's seems like it has a bad ground I've checked all grounds they are ok. this trouble began after I swapped the auto trans for a D/R 5sp
try switching bulbs side to side and see if the problem stays put (wiring) or also switches (bulb).
After using Andy's excellent advise, if you find the problem to be wiring, here is the wiring schematic.
Note there are two relays (seen a little left of center) for the head lites, one for the left and one for the right headlamp. It is possible one of them has bad or burned contacts. You do not say if the problem exists in low and hi beam? Why this relay would give you trouble after a tranny swap is also a mystery.
You say you checked the ground, well the ground for the head lights is behind the coil, yes the coil, clean this one.
But that ground would affect both headlamps.
Probably will not help, but here it is
  • 4 weeks later...
I finally got around to working on my head light problem thanks for all the help.the problem was the left head light relay switch thanks again. ED
