sub_dont_touch Posted June 29, 2009 Share Posted June 29, 2009 Hi, How do you check if your Mass Air Flow sensor is working good or not? My car turns over but does not start. thanks Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 29, 2009 Share Posted June 29, 2009 FSM may give specifications. A visual can show the fine wires of the MAF broken. But I doubt it's your MAF sensor. Best bet for help is more information. What vehicle, what engine, how many miles, any prior problems? What did it do before it didn't start? Crank/cam sensors are more apt to cause a no-start on EJ vehicles. Quote Link to comment Share on other sites More sharing options...
sub_dont_touch Posted June 29, 2009 Author Share Posted June 29, 2009 (edited) 1994. EJ18. 192,000kms. I have tried changing the crank sensor. I put a 600CCA battery on it, it started. Put my 520CCA battery back on, it worked for about a week then died again, wouldn't start with either battery. Starter motor works fine told by auto electrician. Turns over but doesn't start. Edited June 29, 2009 by sub_dont_touch Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 29, 2009 Share Posted June 29, 2009 you need to make sure the starter is getting sufficient voltage. enough power loss will allow it to turn over, but not quite fast enough, those things draw a lot of amps. that's why you're battery will go dead in a matter of minutes trying to start a car. all of that to say - the battery needs to be good. the battery terminal connectors need to be clean and tight. the grounds and wiring for the starter need to be good. any check engine light? that's the first place to start if there is. Quote Link to comment Share on other sites More sharing options...
Mikevan10 Posted June 29, 2009 Share Posted June 29, 2009 If I recall correctly, when my MAF sensor failed, I could start the car with the MAF sensor disconnected (although it would then run poorly), but it would not start with it connected. You may want to try this. Mike V. Quote Link to comment Share on other sites More sharing options...
idosubaru Posted June 29, 2009 Share Posted June 29, 2009 I don't think that's definitive. I've heard people say that before but i've went and unplugged mine before and the car wouldn't start. maybe certain engines are different? Quote Link to comment Share on other sites More sharing options...
sub_dont_touch Posted June 29, 2009 Author Share Posted June 29, 2009 yes there is check engine light. The connections are all fine. Battery has been tested, good. Battery charged up over night. Quote Link to comment Share on other sites More sharing options...
bheinen74 Posted June 29, 2009 Share Posted June 29, 2009 I don't think that's definitive. I've heard people say that before but i've went and unplugged mine before and the car wouldn't start. maybe certain engines are different? same here unplugged the maf, could not start... Quote Link to comment Share on other sites More sharing options...
sub_dont_touch Posted June 29, 2009 Author Share Posted June 29, 2009 I tried unplugging, it wouldn't start. The check check engine light shows along with the radiator (looks like it) light, battery and check engine. A few seconds later the oil light comes on. Quote Link to comment Share on other sites More sharing options...
