beans Posted July 7, 2009 Share Posted July 7, 2009 alright i have a 1986 subaru gl wagon. i have swapped a ej22 into it.. since the swap the car will piss gas out the canister at random points in time.. please help i will drain the whole tank and that gets costly.. anythoughts will help Quote Link to comment Share on other sites More sharing options...
nipper Posted July 7, 2009 Share Posted July 7, 2009 Is it possible that your gastank is getting pressurized, and the only place for the gas to go is out the canister? If this is so (and I think it is) this is a dangerous thing. Check your vacume line routing. I dont know this year well enough to know the vac diagram off hand. nipper Quote Link to comment Share on other sites More sharing options...
beans Posted July 7, 2009 Author Share Posted July 7, 2009 im not sure about vaccum lines. it possible... i dont know if it matters but the motor is a 93 ej 22.. also i have been running without a gas cap Quote Link to comment Share on other sites More sharing options...
Numbchux Posted July 7, 2009 Share Posted July 7, 2009 even with no gas cap, it pushes fuel out the vent line? here's the post that led me to try running with the gas cap loose: Maybe the lines on the fuel separator are a bit gummed up from sitting so long. I'm pretty sure my loyale had sat for a long while before I got it and had some issues with pressure building up in the tank for a while and they eventually went away on its own. Once you burn some gas out of the tank maybe you could blow out the little lines behind the filler pipe on the tank. One goes to the top of the separator and the other is at the bottom of the separator draining back into the tank. This is assuming the evap system is the same as the loyale and assuming those lines aren't too crusty to get loose w/o breaking something, lol. Or we can do what I did and just let the gas eventually dissolve whatever crud is causing the pressure. I got lucky. after a couple tanks of gas, it seemed to solve itself. but Dhise mentions cleaning out the separator.....that might be your next step. Quote Link to comment Share on other sites More sharing options...
beans Posted July 7, 2009 Author Share Posted July 7, 2009 (edited) i suppose that is what i will do. ill let you know if it changes anything. i have hanyes books and factory repair books.. but where is the fuel separator on a 86 Edited July 7, 2009 by beans Quote Link to comment Share on other sites More sharing options...
beans Posted July 9, 2009 Author Share Posted July 9, 2009 ok got the separator out.. now cleaning it.. what would you reccomend cleaning it with Quote Link to comment Share on other sites More sharing options...
Numbchux Posted July 9, 2009 Share Posted July 9, 2009 ok got the separator out.. now cleaning it.. what would you reccomend cleaning it with possibly some seafoam.....or pb blaster Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted July 11, 2009 Share Posted July 11, 2009 You sure that you hooked the return line from the EJ22 to the right hose going back to the tank? There are 3 pipes that the hoses hook up to on the drivers side of the engine, one's the fuel feed, one's the return, and ones the evap. If you swapped the return and the evap, it would be returning fuel through the seperator and fuel from the tank could be coming down the return line and flooding the carbon canister. Quote Link to comment Share on other sites More sharing options...
beans Posted July 13, 2009 Author Share Posted July 13, 2009 ok thats a possibility but would it cause gas to leak out everytime it is ran or just everynow and then.. and also would it cause all the gas in the tank to pour out. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted July 15, 2009 Share Posted July 15, 2009 If you parked with the front of the car facing downhill it could concievable siphon the gas out of the tank and out the carbon canister vent when the canister saturates. Check your hose routing. Quote Link to comment Share on other sites More sharing options...
sxe111 Posted August 18, 2009 Share Posted August 18, 2009 I just experienced the same thing with my swap. Did you every figure out what was wrong? Quote Link to comment Share on other sites More sharing options...
beans Posted August 19, 2009 Author Share Posted August 19, 2009 i swapped the return and vent line so far it hasnt drained out any gas.!! Quote Link to comment Share on other sites More sharing options...
sxe111 Posted August 19, 2009 Share Posted August 19, 2009 Thanks I will give that a try. Quote Link to comment Share on other sites More sharing options...
WoodsWagon Posted August 21, 2009 Share Posted August 21, 2009 Cool. Nice when it's a simple solution like that. Quote Link to comment Share on other sites More sharing options...
