sub_dont_touch Posted July 17, 2009 Share Posted July 17, 2009 (edited) Hi, I see there are four black relays in the engine bay fuse/relay box. Are these the only relays or is this a big round silver relay somewhere? Reason is that I need to swap a relay with the fuel pump relay in my 94 impreza to see if it bad or not. I pulled out a black a/c relay and tried plugging that in but I'm not sure if this is right or not because my car still didn't start. Edited July 17, 2009 by sub_dont_touch Quote Link to comment Share on other sites More sharing options...
ericem Posted July 18, 2009 Share Posted July 18, 2009 Those relays are for the fans not the fuel pump. They are not the same as the fuel pump either. The fuel pump relay is difficult to access but if you remove the cover below the steering wheel and look on the left side in a little area you should see this badboy. You will need long needle nose pliers to get to it and once its out its difficult to put back so just leave it somewhere more accessible like I found mine. Quote Link to comment Share on other sites More sharing options...
Olnick Posted July 18, 2009 Share Posted July 18, 2009 Nice pic. Which one is the fuel pump badboy? Quote Link to comment Share on other sites More sharing options...
ericem Posted July 18, 2009 Share Posted July 18, 2009 round silver one. Brownish one is the ignition relay. It is a very tight area but you can break the relays out of place with long fishing needle nose pliers then stick your hand in and grab the wires to pull it out. Quote Link to comment Share on other sites More sharing options...
sub_dont_touch Posted July 18, 2009 Author Share Posted July 18, 2009 thanks for the help but I know the fuel relay. and the ignition relay. they are on the same bracket, along with a white plug relay. What i need to know is what relay i can swap around to see if my fuel relay is bad or not. cheers Quote Link to comment Share on other sites More sharing options...
