EA71 headgasket question...
So i've got a set of "new" Subaru OEM headgaskets for fat-case EA71's and I just noticed something...
It doesn't have holes for the coolant passages on the sides of the heads/block. What gives?
Nobody?
Should I take some pics to show what I mean?
My other, non-fat case EA71 that I had in my '78 wagon had headgaskets that DID NOT block those coolant passages, so i'm not sure what should be done about this.
looking at a felpro fat-case gasket.. I recall ea81 gaskets also had some of the passages restricted/blocked.
My guess is that is has to do with restricting the flow so it circulates in the block & heads in a specific pattern to maximize heat absorption. the early ea71s did have problems with grenading pistons, perhaps this was a solution to these "hot spots"?
I can't see any restrictions in the FPM's ... I don't have a lot of time to research right now,sorry.
there's a certain board member here who grenaded the #4 on a 78 Brat. :(
I've had two self-destructed ea71s in the past from pistons giving up. :rolleyes: Such is life
