Carb'd EJ?
We never got the carb'd EJ engine - only fuel injection over here UNLESS it was a grey import which means that it was not shipped to australia by subaru australia...
That's awesome!
Cheers
Bennie
yeah im not sure how good an idea it is to carb an EJ since their fuel injection system is excellent already but i would love to see about putting a harley carb on my ea81. even though to be honest my weber should work fine.
  • Replies 58
  • Views 21.1k
  • Created
  • Last Reply
Top Posters In This Topic
Most Popular Posts
  • simple. the carb is up to you.there are places to buy the manifolds, or you can make one. the distys are a stocked part by napa, or any ford guy you know that had escorts,exp's or merc lynx's.pretty
  • Scott in Bellingham
    Scott in Bellingham
    heres mine, simple and am looking to do it again in my next car
  • The Beast I Drive
    The Beast I Drive
    Ive seen a couple of those carbed EJs in person, personally thats my preference, I like carbs. Throttle linkage is no problem, Weber has throttle bracket kits that bolt to the carb, and aftermarket co
Hi This is Jerry, i have a holley 4 barrel carb on my 2.2 and holy cow it knows how to smoke the tires.:lol: Thanks Jerry
that might work on an ej but ill bet on an ea81 youd be loosing more fuel then what is getting into it.
Is there a groove for an o-ring on the Escort disty to seal the back of the head and does it fit w/o mods to head or disty? If so I'm going to get one :)
Yes, on mine, there is a recessed groove with an o-ring seated into it. The head is slightly beveled at the outside edge, so it just took a little taping around the distributor to get it seated. Oil the o-ring first, makes it much easier.
The adjustment/bolt down grooves needed to be widened ever so slightly. I just used a slightly larger drill bit, placed dizzy on a firm surface and let the bit widen the grove. i had to go over it a few times to smooth it out though.
Muscle Building Program
The only reason I am doing this setup, other than my curiosity and imagination running away from me at this point, is because my wiring, comp, sensors or some other crap included in the whole EFI setup is hosed. This is my first experience with an EFi that I have had to screw with, my other fuel injected cars all run great.
The 2.2 runs like a bat out of hell with efi, just not consistently. Unless I really fall in love with this setup, my intent is to megasquirt this thing as soon as I have the cash to get the setup.
I have the 2 barrol weber from the 1.8, It was awsome on it. (Read the post about how I smoked and humiliated an RX-8) If anything, I will only need to re-jet the carb. But I know a LOT about NA engines and am not at all concerned about the functionality of the finished project.
Chaz
Good news that the diameter of the mating surface of the Escort disty nearly matches the EJ head, I guess it is time to browse Ebay some more for old blue oval disty's!
I already have a set of original EJ carb heads and the intake manifold with Hitachi carburettor so that disty would complete my setup.
I marked out the holes.
Cut the holes using a hole saw and an electric drill.
Mounted My adapter plate...
Holy Cow! ... Good Job but: how could you keep clean the internals of that intake, from the metal debris?
I Mean: if you did that Job right there, some metal debris could be Swallowed onto the Combustion Chamber with Potential Damage ... icon4.gif ...
Debris? I have a custom drill attachment that connects to a 10 hp vacuum for the initial drilling and a telescoping vacuum attachment that snakes in to each port. That and I took off the throttle body and stuffed it with automotive seat cushion foam so that nothing could drop in. :)
  • 4 years later...
Well... Finally, I Have the Numbers :)
I Obtained the Number of Each Part, but let me Tell you that there are Two Different Part Numbers for the Complete Distribuitor for Subaru EJ Engine, but Both Use the Same internal Parts.
  • The EJ Engine Distribuitor is Listed in the Dealer's Manual with Part Numbers:
22100 - AA460 and 22100 - AA550
  • The Rotor Head is Listed with Part Number:
22157 - KA060
(item Nº 15 on the Manual's List)
  • The Cap-Assy is Listed with Part Number:
22162 - AA090
(item Nº 14 on the Manual's List)
EJ22 Dizzy location at end of video and 4bbl comments:
